No Reverse
Old Apr 24, 2012 | 02:34 PM
cummins kyle's Avatar
Default No Reverse
Hello i have a 1998 dodge ram 2500 12 valve with a stock automatic trans.
The other day i went out to leave school and it would not go into reverse. When i put it in reverse in does not go anywhere but when i put in neutral it will drive forward same with drive 1st and 2nd. When i have it in reverse it does not free rev it revs like the torque converter is engaged. Same with park it revs the same way reverse does. Thanks for your help
Old Apr 29, 2012 | 05:45 AM
welderboy250's Avatar
I would say u slipped the forward clutches so bad they welded themselves together. It's basically in first gear even without any pressure so even park or neutral it try's to go. The forward clutches have to release in order to back up and since they can't it's a no go. It will require the trans to be pulled out and rebuilt.
Old Apr 29, 2012 | 11:26 AM
Ok thanks for your help
alexcummins2341
Jul 31, 2015 11:21 PM
99&91cummins
Feb 28, 2015 09:28 AM
97PS
14
Feb 19, 2015 11:21 AM
crusty
Feb 14, 2015 08:56 PM
