injector install
how hard is it to remove and install injectors in a 1997 f350 7.3. i have a general idea how to do it i just want some input. iv done glow plugs just aint to sure about the injectors. any advice would be apriciated.
Remove valve covers
unhook injector wiring
Remove bottom hold down bolt
Slide collar up over the top hold down bolt and pry up on injector
Repeat last step for 8 times
Coat new injectors in oil and slide into the hole, collar over top hold down bolt
Use soft mallet to tap injectors(careful of the solenoid) until firmly seated.
put bottom bolt back in place and torque to 120inlbs
repeat last 3 steps 8 times
remove glow plugs
put valve covers back in place for with a bolt on top and bottom
bump the starter a few times to make sure everything will spin freely
remove valve covers and replace glow plugs.
hook all the wiring back up to glow plugs and injectors
reinstall valve covers
jump in the cab and start cranking about 15seconds for 3-5 cycles.
should fire up and might be smoking like a train.
take it out for a drive, it might miss and skip but it's air in the system. Will take upwards of 100 miles to get driving right. Also, your start ups for a day or two might take a few extra seconds of cranking. It's normal.
remove glow plugs
Really? Just a nut driver and the vacuum box comes off... Unless it's covered in foil, mine wasn't so it was just as simple as removing the screws...
