85 6.9 fuel issues
Old Apr 17, 2012 | 04:28 PM
Hyrail's Avatar
Default 85 6.9 fuel issues
Hey all,
Been having some issues with the 6.9 I own, seems to be sucking air at times and when parked seems to lose prime. Just started a few months back already did injectors and the fuel lines look good. I just replaced the lift pump since it was leaking oil and I figured that was the problem. It ran great after I put the pump in then when I got fuel it started the surging/light smoking thing.(new fuel filter already didn't help) this problem is not constant, truck does not miss and the water separator has already been by passed. When I fill the tank I have to go slow on the nozzle or it "burps" out the neck, is there a breather valve on the fuel tank that could be clogged that could cause fuel starvation/air ingestion?
Old Apr 17, 2012 | 07:53 PM
HELLBILLY8687's Avatar
posable air in return lines.. i have new return lines and mine still does it
Old Apr 18, 2012 | 07:15 AM
Hyrail's Avatar
Already changed those after I bought it since they were leaking that was over a year ago, guesss I'll have to do some more chasing. Just looking for ideas on where to start.
Old Apr 18, 2012 | 04:16 PM
DieselCrawler's Avatar
you already nailed all the normal culpruts. have no idea now.
Old May 2, 2012 | 02:41 PM
Hyrail's Avatar
Hellbilly, got mine narrowed down to between the tank and filter housing, think its one of the metal lines plan on working on it in a few weeks I'll keep you posted
Old May 3, 2012 | 12:40 AM
4x4manonbroke's Avatar
I replaced all the fuel lines with Gates Bio- diesel line... truck runs freekin awesome...
Old May 3, 2012 | 07:51 PM
7.3 idi 1990's Avatar
might be fuel feed pump
Old May 3, 2012 | 07:57 PM
ALWAYSREADYROB's Avatar
does it do it on both tanks or just one ?
Old May 3, 2012 | 08:20 PM
mine was only doing it on the rear tank... but I replace all the fuel lines with boi-diesel line .... now she dont miss a beat... and I'm killin P.S. trucks with turbos.... mine is a N/A..... I think that is just awesome..
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
J. Nick
Apr 25, 2015 05:01 PM
12Valvepower01
Mar 30, 2015 03:41 PM
moneypitk5
Feb 12, 2015 11:01 AM
