Help with headlight bulb replacement!!!!!
Old Apr 17, 2012 | 08:40 AM
OILFIELDTRASH's Avatar
Default Help with headlight bulb replacement!!!!!
Hey guys how's it going? Im new to the forum as well as the 4th gen dodges. I bought some silver star bright headlight bulbs but couldn't figure out how to get the stock bulb out. Do you have to take the whole light off the truck? And if so dost that require me to take my grill off too? Also any pics of job and has anybody used these bulbs and did you like them? Thanks
Old Apr 17, 2012 | 11:04 AM
Eddiebuntain's Avatar
Do you have the owner's manual? Should have instructions in there. I don’t know about a forth gen, but on my 01 the bulb can be replaced without removing the housing, gotta squeeze past some obstacles, or remove 'em.
Old Apr 17, 2012 | 01:53 PM
Longhorn's Avatar
Yes the whole assembly has to come out, but not the grill. Its an easy task, there is a panel under each front fender with a nut to remove, then the rest just pulls off. It is all explained in your owners manual as well.
BTW the Silverstars will not stand up to offroad use and will burn out in half the time on road...they are brighter and I like them but they burn out quickly. I have had better luck with the PIAA bulbs but none have lasted as long as the stock bulbs
Old Apr 17, 2012 | 02:03 PM
Ya my manual don't show anything on iv iv looked it over 1000 times but ok I'll look n see if I can find those bolts n give er a try. But ya I kno the won't last as long as stock but the brightness on stock sucks its the only thing I don't like about this truck will update with my luck thanks guys
Old Apr 17, 2012 | 02:19 PM
Yeah, the manuals are generally organized in the goofiest way possible. Given enough time and patients, so far I've been able to find most things I look for, but it often takes a while. When I get a new (to me) vehicle, I always pick up a Haynes or Chiltons service manual, they have most routine maintainance information that I want, organized in a sensible manner.
Old Apr 17, 2012 | 03:29 PM
Ya I just haven't had the time to pick one up. But update on headlights for the 2012 2500 there is 3 bolts on the head light one behind the fender under the flap and 1 just under the hood and one behind the grill at the bottom, u have to take the grill off to pull the headlight out because you must pull the headlight assy towards the grill to pull the lil tab out of its hole. Kind of a pita but gotta be done.
Old Apr 18, 2012 | 10:24 AM
Longhorn's Avatar
My apologies, I thought it was the same as the 2008...
Good instructions here:
DS Body Headlamp Removal - Dodge Ram Forum - Ram Forums and Owners Club! - Dodge Truck Forum
Old Apr 22, 2012 | 11:48 AM
peters0756's Avatar
Just a thought but they should make the engineer that designed that change headlights for a year and they would probably start thinking about what they are putting into these trucks.
Old Apr 24, 2012 | 06:20 PM
jp_hotwheels's Avatar
There's a slide clib behind a small panel inside the wheel well, I had to remove my grill to get the front bolt that holds the assembly in, I replace the assembly with a spec-d setup, go to their website, they have a PDF download that shows you how to get to everything. Didnt see any other way to get to bulbs without removal of assembly.
Old Apr 25, 2012 | 07:39 AM
And they should make big truck engineers change oil in truckstops a few times a year. The new Cummins is a major pain and the DD15 is a joke.
Rigman
Jun 19, 2015 02:15 PM
May 31, 2015 08:10 AM
makuloco2000
Feb 15, 2015 02:31 PM
Lawrence D. Sanders Sr
Jan 23, 2015 12:47 PM
