Fuse blow on AIRDOG 150
Old Apr 16, 2012 | 08:11 PM
articcummins's Avatar
Default Fuse blow on AIRDOG 150
For the last 2 weeks I have a problem with my AirDog, it blow fuse two time. I inspect the wiring and I replaced the filter and the water separator but it blow a fuse again today. My AirDog is about one year old, my truck is a 2004. The fuse is a 20 AMP did I should put a stonger one, I have no idea what is the problem..... any idea.
Old Apr 16, 2012 | 08:22 PM
Fire Power's Avatar
Its possible the motor is bad that will cause it to blow fuses What does it sound like healthy or screechy
Old Apr 17, 2012 | 07:00 AM
Deezel Stink3r's Avatar
No idea about the pump- but the 20A fuse is already a big sucker. Do not replace it with a bigger one! 20A x 12V equals 240W - there is going something wrong if this fuse blows!
Remove the pump and test it! I'm sure there is a minimum flow per minute comparision chart.
Old Apr 17, 2012 | 05:50 PM
I will do that tomorow, remove the pump from the truck and try it. The pump dont give any sign of a problem..
Old Apr 25, 2012 | 07:56 AM
Default Problem FIX
I open the pump and it's all toasted inside, I call AirDog and they are sending me a new pump on waranty. Good service from AirDog.
Old Apr 25, 2012 | 08:51 AM
RAW's Avatar
RAW
That's great news to hear!
stone9291
Jul 23, 2015 05:13 PM
david.burger
May 30, 2015 08:25 AM
rollover
May 5, 2015 07:33 PM
justinsbeck
Nov 21, 2014 11:53 AM
Altonlee
Oct 1, 2014 04:58 PM
