98.5 24v 4x4 brake issue
Old Apr 14, 2012 | 05:48 PM
gene.mneil's Avatar
Default 98.5 24v 4x4 brake issue
Mt problem started when the line going to the front driver side caliper busted. We put a new line in and bled everything. Had no rear brakes. Took to to a shop they replaced calipers, and the master cylinder. Still no rear brakes ans pulls to the right. I replaced the proportioning valve. Still no rear brakes, even after adjusting them they just release back off. Now they started going soft randomly. It hoes to the floor with very little brakes. So I tossed a new brake booster on it. Before I go ape **** has anyone else had this issue? Or know a possible fix?
Sorry about typos, im doing this from a phone.
Last edited by gene.mneil; Apr 14, 2012 at 05:48 PM. Reason: Automerged Doublepost
Old Apr 14, 2012 | 06:34 PM
RanchhandTCR's Avatar
Are your adjusters in the correct dirrection and are not backing off??? instead of adjusting in? Ive havnt had the problem.
Old Apr 14, 2012 | 10:42 PM
gene.mneil's Avatar
The shop said everything was good. Bit now at random times the pedal drops to the floor with no brakes at all. This is insane...
Old Apr 14, 2012 | 11:09 PM
Power steering pump??? the brakes are related to the steering on these trucks?
Old Apr 15, 2012 | 09:23 AM
gene.mneil's Avatar
New pump, gear box, all fluids are good. Have I given you the wtf syndrome yet? Lol
When I drive a few miles it stops just fine, but after I push the pedal ans start to stop if I let off of the pedal and reapply pressure it loses all pressure and drops to the floor.
Last edited by gene.mneil; Apr 15, 2012 at 09:23 AM. Reason: Automerged Doublepost
Old Apr 26, 2012 | 01:28 AM
greasemonkey29's Avatar
Is your abs or brake light on?
Renteria1217
For Sale
Aug 16, 2015 09:43 PM
Turbo67
Jul 25, 2015 02:26 PM
Craigdegolier
Jul 20, 2015 04:46 AM
gd1996
For Sale
May 15, 2015 09:42 AM
rwurbanwildlife
Mar 6, 2015 01:03 PM
