fueling 6bt 97f350
Old Apr 11, 2012 | 07:01 PM
codycatract's Avatar
Default fueling 6bt 97f350
i am putting a 6bt in my 97 crew cab, im trying to figure out the fuel, i heard the ve pump cummins needs a feul pump that runs 90gph at 13 to 16 psi, the stock tank ford ones will not keep up the the gph. is there a replacement pump i can put in tank that will have about 100gph at 1 psi so i can bypass the mechanical one and keep everything the same? or run the stock electric tank pump with the mechanical dodge pump?
Old Apr 11, 2012 | 07:06 PM
Billy D's Avatar
Just run the mechanical
Old Apr 11, 2012 | 07:44 PM
i think i might use the electricc ones and mechanical, so i can still switch tanks with my switch and run pressure reg between injection pump and have fuel presure gauge
Old Apr 13, 2012 | 07:09 PM
Is the fuel pump in the front tank of a 97 f350 exterior? It looks like a pump in frame right next to tank? If its not pump what is it
Old Apr 15, 2012 | 09:59 PM
I've done alot of reading and everywhere I have researched it has says a 1997psd does not have electricfuel pumps??? I thought it had tank pumps along with the mechanical lift pump, and the tank switch changed tanks by turning on the opposite tank pump? What is true?
Old Apr 17, 2012 | 01:14 AM
not enoughsmoke's Avatar
i have a ve with a stock diaphram pump and a lil pusher pump at the tank to help push it to the mechanical one
Old Apr 17, 2012 | 07:43 AM
What are the specs on the helper pump. And I have been told by a number of people my 97 pad does not have electric pump? Is that true
Old Apr 17, 2012 | 10:33 AM
its a cheap pump from o'rieliys its a 5-7psi pump inline style like 20-30 bucks
was your truck a factory gas or diesel the factory diesel had a pump on the motor the gas had one on the frame.What ever you do DO NOT EXCEED 15PSI on a ve it will push the front seal in the pump out and ruin the motor
Old Apr 17, 2012 | 11:48 AM
Factory 7.3. So it only has the one on the motor?
Old Apr 17, 2012 | 06:24 PM
yep
ReckONE
Feb 25, 2015 09:41 AM
jtwthaxj
Jan 14, 2015 06:52 AM
BCOWANWHEELS
Wanted To Buy (WTB) - Used
Jan 7, 2015 03:42 PM
big tan snorkel
15
Dec 17, 2014 05:04 PM
Slim Whitey
Oct 4, 2014 10:58 PM
