under cab twin turbo problem
Old Apr 11, 2012 | 10:04 AM
morfordmmsty's Avatar
Default under cab twin turbo problem
Ok so I had a stock turbo setup I got of a 94 and I decided that was not enough so I just put a new bbottem end together to handsome a little more psi and I have installed twin turbo s and it works great but I am having a problem getting the oil back into the pan has anyone mounted turbos under the cab and had this problem any ideas on a fix? Thanks in advance
Old Apr 11, 2012 | 10:27 AM
"SmokinIDI"'s Avatar
if you are sayinng that you literally mounted them under the cab then you would have had to run tubes back up to the motor for oil and intake. so maybe if thats the case then there may not be enough pressure to pull the oil back up the tube to the motor
Old Apr 11, 2012 | 12:01 PM
6.9idimonster's Avatar
If the turbos you mounted are gravity return and they are lower then the pan that could be your issue
Old Apr 11, 2012 | 02:23 PM
I have 9 psi going into the turbos and less than 1 coming out so I guess do you know of anything that can be spliced into the return line to help lift the oil back up the foot it needs to go to get to the pan I have heard of people using the mechanical fuel pump to do this before but I am trying to avoid doing that if possible
Last edited by morfordmmsty; Apr 11, 2012 at 02:33 PM. Reason: auto correct screwed up my post
Old Apr 11, 2012 | 07:26 PM
DieselCrawler's Avatar
there are pumps to scavenge oil back to the block.
Old Apr 11, 2012 | 07:38 PM
Yeah thanks I had just found one in a kit but having a hard time finding one to buy separate do you know of any brands available
Old Apr 12, 2012 | 05:02 AM
nope
Old Apr 12, 2012 | 08:59 AM
LORDDiESEL's Avatar
We need some pics of this set up.
burndiesel
10
Feb 7, 2023 01:15 AM
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
