getting closer but I am stumped tach sense 12v -99 ford
Old Apr 3, 2012 | 10:47 PM
deck60's Avatar
Default getting closer but I am stumped tach sense 12v -99 ford
I would like to use the stock 98 dodge tach but from what i found
#1 blk lt blue ground
#2 vio white 5 volt supply
#3 gry blk tach feed
but I dont have those color wires it is a 98 12v I know I can use the cam sensor from the ford but I wanted to keep this part stock if possible
Old Apr 8, 2012 | 08:21 AM
cumminsf150's Avatar
did you put the dodge gauge cluster in the ford?
Old Apr 8, 2012 | 08:39 AM
deck60's Avatar
no ford gauge cluster
what I have found out on the tach thing the cam sensor will work in place of the cummins just have to ground one wire and take and splice 2 wires at pcm connector
but I would love to be able to use the cummins sensor I should be able to tell you in a couple of days if it will work or not
this is how i wired it up
cummins side
black-- ground
red--- 12v feed
green--- sensor
ford side
used cam sensor wires
one wire hooked to black and ground
other wire sensor
pcm
took #48 & 85 and tied them together before pcm
hope it works
atreefunk
For Sale
Apr 13, 2015 10:57 PM
short12
Jan 2, 2015 04:56 PM
Nov 4, 2014 01:30 PM
Oct 14, 2014 08:40 AM
