Audio Equipment/Electrical Discussions Based on Automotive Stereo Equipment Such As Amps , Head Units & Speakers Including Installation and System Set Up Information. Electrical or wiring issues on anything that requires wiring.
Cluster LED Mod
Old Apr 1, 2012 | 07:34 PM
2004LB7's Avatar
Default Cluster LED Mod
so i just replaced all of my incandescent bulbs in my cluster with LEDs.
here are some photos
use tape and a mark to be able to realign the needles
Best way to remove the needles
all of the old bulbs removed
750 ohm resister and LED soldered in
another LED soldered in
all of the LEDs are in
testing before putting it all back together
some areas will be tight so make sure you plan out where to put the resisters
all done. looks good
parts needed: 12x wide angle white LEDs, 12x resisters (i used 750 ohm 1/2 watt), soldering iron & solder, 7 MM nut driver, roughly one half to one hour of time depending on skill level
Old Apr 1, 2012 | 08:19 PM
daveO's Avatar
Nice.
Old Apr 9, 2012 | 09:34 PM
s10driver85's Avatar
i really like this, did you change the color of the lights? and do they dim?
Old Apr 9, 2012 | 09:41 PM
H.R.D's Avatar
Old Apr 10, 2012 | 01:23 AM
mannblack's Avatar
Sweet looking!
Dimmable?
Ch
Sent from my DROID RAZR
Old Apr 10, 2012 | 01:32 AM
2004LB7's Avatar
i used white LEDs but they turned out to be of the cool white verity so slightly blueish.
yes, it is fully dimmable.
the turn signals are a bit on the bright/washed out side. i would suggest to anyone trying this to use green LEDs for them
otherwise i think it looks great and is well worth it. the slight blue nature of the LEDs do add a nice contrast to the red/orange needles
Old Apr 10, 2012 | 04:53 AM
2500HeavyDuty's Avatar
bad freakin ***!!!
Old Apr 10, 2012 | 09:25 PM
really got me wanting to tear my dash out.... cant wait untill i burn out a light....
Old Apr 26, 2012 | 12:15 PM
davidyack's Avatar
I just did the same in my dodge, but it was a lot easier. Uses wedge bulbs. I did have to solder all the leds for my switches and hvac though. Yours looks great. Very clean.
Old Apr 26, 2012 | 01:00 PM
RAW's Avatar
RAW
I changed all the wedge bulbs as well, but intend to do them all. It looks horrible to have an orange or red light on when everything else is a beautiful blue.
