new build need some help!
Old Mar 29, 2012 | 09:32 AM
pullincrazy88's Avatar
Default new build need some help!
Hey guys new to this forum and figured this would be a good place to get help with my build.... Im taking a 96' cummins out of a bus and putting it in my 2000 chevy k3500 with a VN4500. right now the truck has a 7.4 vortec in it with an automatic trans in it, and I plan on keeping the pcm in it to make all the factory guages work properly. But the point of this post is I have a few questions.
Where and how is the the tach out put hooked up for RPM reading.
Anyone running a 4:10 gear behind there nv4500 hopping it doesnt make first gear useless unless your pulling a house down and what kind of rpm are you seeing running in the 60-65 mph range.
Also I will be either setting the engine up or doing it all at once but I'm looking to make as much power as I can while the truck still gets the best fuel economy and can still pull a trailer with out running my egt's through the roof with a heavy load.
Any help with these questions or any more in the future are greatly appreciated!
Old Mar 29, 2012 | 06:17 PM
EasternAggie's Avatar
Even with 3.55's, unless you're towing, first gear is still worthless. Everybody I know starts out in 2nd gear. With 4.10's, 2nd gear is still going to be pretty low.
Old Mar 29, 2012 | 08:29 PM
i was afraid of that. and my tire would probably be a 285
Old Mar 30, 2012 | 03:23 PM
How heavy and how often do you tow? 3.55's should still tow pretty good, but if you need something lower than that, you might consider 3.73's.
Old Mar 30, 2012 | 04:31 PM
usually never more then a deckover or car hauler with a full size pick up on it, and maybe twice a month. ive decided that i do need to swap the gears out but the 4:10's will have to work for a little while as im not gonna have the extra money after doing the swap. but to what gears idk not sure what gm offered between a 3:73 and the 3:08 i believe it is.
bigbadDT
Aug 28, 2017 06:36 AM
redveloce
38
Jan 22, 2017 03:55 PM
DODGEARMYGUY
Feb 8, 2015 07:08 PM
jtwthaxj
Jan 14, 2015 06:52 AM
Oct 15, 2014 12:30 AM
