06-07 LBZ Performance Discussion of Chevy and GMC Trucks with LBZ Duramax Turbo Diesel Engines Related To Performance And Longevity
egr blockoff ?
Old Mar 27, 2012 | 10:28 AM
junkit's Avatar
Default egr blockoff ?
Hello, about a year ago I sold my ol reliable 05 chevy 35004x4 lly with 270k "all stock". I bought an 07 classic about a year ago with 90k . Clean truck. Never had a minutes trouble from the 05. Engine light is on the 07 The light has been going on & off for about a month, lasts for a few days then goes off . Dealer says its an egr problem ? I pull dump trailers every day 10-15k & I'm pretty easy on it. does have a 4" exhaust & I bought a $200 edge juice w/attitude & put on about 3 months ago & run on the towing or economy setting. My question is, is it necessary to do this egr block-off ? will it effect the computer / performance of the truck?
Any input is appreciated. I'm not that knowledgeable on the d-max yet, just dont have to work on em much! I came from the 7.3 psd
thanks
Old May 2, 2012 | 01:09 PM
jevanb's Avatar
does it have a turbo down pipe?? and with the kitty gone their is lots of flow out the manifolds and the EGR sees low flow hence the code, i got the code only once since I removed the factory DP and took the kitty off, some trucks are more prone to the code then others. if your egr valve is working get EFI or PPE and disable the codse and block, or blocker plate and finger stick with your programmer you have now, but from what I understand the valve has to work for the blocker plate and fingerstick to work. hopes this helps
Old May 3, 2012 | 09:41 PM
BriteWhiteRam's Avatar
the valve becomes useless as soon as the block off plate is installed, and for the Less than $20 you will spend on that mod it is well worth keeping all that sticky sooty mess out of the intake
to eliminate the code you need either a finger stick or a PPE xcllerator or EFI live, the Edge wont eliminate it
Old May 4, 2012 | 12:11 AM
2004LB7's Avatar
^^ 2x
block it and turn off that code
Old May 12, 2012 | 08:28 PM
jevanb's Avatar
I ran up the mts of kentucky and tenn on the way back from tampa last week and with the long down hill runs I get the code, on the flats I never get the code
syctaz
Jun 26, 2015 12:20 PM
willyam
Price Quote - Request A Price
May 19, 2015 10:20 AM
dscp
Apr 17, 2015 02:51 PM
Bighouse
Apr 9, 2015 06:51 PM
tbreddiesel
Thoroughbred Diesel
Jan 12, 2015 02:23 PM
