1997 Ford Powerstroke
Old Mar 25, 2012 | 05:48 PM
Tyler Golis's Avatar
Default 1997 Ford Powerstroke
My 1997 ford f 250 diesel is leaking diesel fuel in the valley. Any idea whats wrong?
Old Mar 25, 2012 | 06:03 PM
CSIPSD's Avatar
fuel bowl drain more then likely. If not it is the fuel pump...
Old Mar 25, 2012 | 06:22 PM
94turbostroker's Avatar
Also check your fuel lines and the sensor that is on the back of the bowl that's where mine was leaking from
Old Mar 26, 2012 | 09:07 PM
97powerstroker's Avatar
there is a cone shape silver sensor on the drivers side that can leak like a siv if it unthreads or goes bad
Old Mar 26, 2012 | 10:31 PM
chromehound's Avatar
I thought my '96 was a leak in the valley but it was the steel line (pass. side) that feeds the back of heads had the o-ring go bad and sprayed fuel all over. Just something else to look at.
Old Mar 27, 2012 | 09:11 PM
firedawg273's Avatar
I thought mine was the valley, but its the water in fuel sensor that comes out the driver side of the bowl. I read on another thread that you can buy a new sensor on ebay, or if ur not concerned about the sensor you can install a brass male plug to fill the hole. Just dont overtighten.
Old Apr 1, 2012 | 04:56 PM
justanother92's Avatar
What these guys said!
makuloco2000
Dec 20, 2015 11:19 PM
makuloco2000
Feb 15, 2015 02:31 PM
leaderbeanjr
For Sale
Jan 20, 2015 01:22 PM
