Fummins fuel return line/tank vent ???
Old Mar 25, 2012 | 11:46 AM
6BT-F350's Avatar
Default Fummins fuel return line/tank vent ???
Doing a 5.9 swap in my 1985 F350 4x4 and was wondering how the fuel tank is vented. I have the factory main feed line that will go to the lift pump, then there is a smaller steel line that went to a charcoal canister up front, is this small line how the tank vents, can it be used for a return line???? Thanks for your help
Old Mar 25, 2012 | 01:00 PM
94cummins12v's Avatar
im guessing your truck wasnt diesel to start the tank actually had a vent on my tanks themselves and self venting caps i did a 1/2 in draw straw from my front tank snd did a inline pump between the rear tank and the front tank of my truck
Old Mar 25, 2012 | 08:55 PM
6BT-F350's Avatar
It was a gas truck.. I pulled tank out today to inspect and get all the gas out. There is a vent on the top but that originally went to the charcoal canister up front so I will keep that as a vent may try to braze an extra tube in the sending unit as I can remove that from the tank so no big boom...
Old Mar 25, 2012 | 09:21 PM
deck60's Avatar
the lid that you want to braze to I am betting it is stainless if you want to do anything run some stainless tubing and tig it or drill a hole in tank and run a line that way
Old Mar 26, 2012 | 03:42 PM
EasternAggie's Avatar
This is how mine is setup...
The factory in tank pump is in the truck. Power is cut to the pump, but still goes to the fuel level sender. I made my own pickup tube for the send line, I believe it is a copper brake line that runs down the length of the pump. For the return line I ran it into one of the old lines that went into the pump, but cut out a section of the line inside the tank so the fuel could freely flow out. The vent line still runs to the engine compartment; the charcoal canister is gone, but the line has a filter on it to keep dirt out.
Old Apr 22, 2012 | 07:15 AM
6BT-F350's Avatar
Found the solution for my return line.. Went to Summit racing and found a bulkhead an-6 fitting and a 90 degree an-6 to barbed adaptor. NO welding or brazing on a tank that had gas in it but still have to drill a hole... Anyone make a brass drill bit?? HEE HEE
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
