just bought a 88 7.3 idi
Old Mar 24, 2012 | 06:43 PM
sik88idi's Avatar
Default just bought a 88 7.3 idi
hello guys so i just bought my first disel ...i wanna change all the filters n stuff ..do u know how many quarts of oil these use some ppl say 15 qt and other say 10 so i rather ask u guys since you guys lknow was up thanks...
Old Mar 25, 2012 | 08:47 AM
blacksmokeaintbroke's Avatar
10 or 11 depends on what oil filter,powerstrokes may use 14 or 15.change your fuel filter alot of people dont,i always pure some atf in the new filter bump the starter dont let it start yet so the atf sets in the lines,pump,and injectors.good luck with the new rig.
Old Mar 25, 2012 | 09:22 AM
1999stroker's Avatar
It ain't 15, that's on powerstrokes only! Id say change your oil, and put in 9-10 quarts bump start it then check the level
Strokin' Away
Old Mar 25, 2012 | 04:31 PM
DieselCrawler's Avatar
10 with the stock filter. 11 if you run the larger better fl1995 filter for a powerstroke. it will thread right on.
Old Mar 29, 2012 | 11:27 AM
4x4manonbroke's Avatar
my truck has a 88 california motor and it takes a solid 11 with a filter.... i typically just buy a case and have 1 left over.... but i'm also running 1 qt of lucas pure syn. oil stabilizer, and Z-max....... with the pump turned up i'm averaging 18 on the freeway now..... if i turn it back down i can get 20mpg.
Old Mar 30, 2012 | 09:27 PM
20mpg awesome,14-15 but im always pulling my trailer.
Old Apr 2, 2012 | 10:01 PM
14-15 with a load is great.. I'm running royal purple 15/40 with z-max and Lucas pure syn. stabilizer.... i'm pullin 1-1.5 mpg, just after changin the oil alone.. I run 10k between oil changes.
Old Apr 10, 2012 | 07:40 PM
cumminsdzlfan's Avatar
i've got a 7.3 with a 4 speed and as long as i stay below 60 i get around 18-20. pulling is around 12-14 depending on the load. i run rotella 15w40 in all my trucks and tractors.
Old Apr 10, 2012 | 07:44 PM
7.3L OkieTxHick's Avatar
you guys make me feel bad...im afraid to see what i get in mine. at one point it was 17 on the highway, but haven't checked it in forever
Browe347
Dec 11, 2016 02:59 PM
Nick91
May 11, 2015 11:52 AM
Toms73
Mar 23, 2015 08:31 PM
g.logistics
9
Nov 22, 2014 08:54 AM
Browe347
Sep 30, 2014 11:35 PM
