Turbo Removal
Old Mar 23, 2012 | 09:04 PM
94turbostroker's Avatar
Default Turbo Removal
What's the best way or to remove the turbo on a 94 powerstroke. Cause I gotta replace my compressor wheel, and found out I gotta take the turbo out to do it.
Old Mar 23, 2012 | 09:17 PM
97t444e's Avatar
i dont believe you have to remove the turbo to replace the compressor wheel. I think you pull off the compressor side housing and get the nut off with a impact gun go to youtube and search wicked wheel and there is a video by powerstrokehelp showing how to install one
7.3 PERFORMANCE TURBO UPGRADE - YouTube
Old Mar 23, 2012 | 09:31 PM
fordornothing's Avatar
it's easier to take it off. and there is no easy way to do it. just get a 12 pack and get workin in it
Old Mar 24, 2012 | 08:47 AM
haha ya that's what I'll need to take it off. And I looked at it and the new style has a different pedistal so the turbo sits up higher. I've done one on a late 99 and ya it was easy. But then on mine i tried and the bottom of the housing is too close to the valve cover. so that's when I found out I gotta take the turbo off.
Old Mar 24, 2012 | 04:53 PM
yeah the SD turbos are easy to take off. the bottom bolt on the drivers side for the exhaust flange is a PIA. get that loose then remove the up pipes. then 4 bolts on the pedistol and it comes off.
Old Mar 24, 2012 | 08:08 PM
alright I'll do that I just know I'm probably gonna be cussin and everything else cause it seems like nothing is easy on my truck
Old Mar 24, 2012 | 08:28 PM
CSIPSD's Avatar
You have to remove the pedistal with the turbo on the OBS truck. I'd like to kick the asshat that designed that system squarely in the nuts...
Old Mar 24, 2012 | 08:29 PM
well you better get a 30 pack then. and some superglue... for the busted knuckles.
it's a great design isn't it? sure am glad i haven't had to pull one yet.
Last edited by fordornothing; Mar 24, 2012 at 08:29 PM. Reason: Automerged Doublepost
avatardvr
18
Aug 8, 2019 12:38 AM
Finn92
Feb 24, 2015 10:41 PM
n2brk
Feb 21, 2015 09:05 AM
jrsavoie
Feb 6, 2015 09:44 PM
GreenDieselF
Oct 20, 2014 02:05 PM
