cummins swap
Old Mar 23, 2012 | 07:14 PM
codycatract's Avatar
Default cummins swap
i have a 1997 crew cab f350 powerstroke, i got a 6bt cummins from a 1990 i am wanting to put in it. also i am going to do a 5 speed instead of e4od. i have looked into this just want to ask from people that done this. what 5 speed is best for this swap? how would i hook up electronic speedo? how would i run fuel system from tanks? thanks all help is appreciated
Old Mar 23, 2012 | 07:22 PM
fordornothing's Avatar
fuel system would hook up like it is on a PS. the speedo is in the rear diff. why would you want a cummins?
Old Mar 23, 2012 | 07:32 PM
97t444e's Avatar
did the 7.3 in it blow up? What is your reasoning for putting a cummins in it?
Old Mar 23, 2012 | 07:43 PM
Ps? Don't know much abbreviations but I had a dodge cumins but like this obs body style so thought I would try out powerstroke don't like it and spends for mods to much crammed into engine bay I miss my cumins so im going to combined them. Anyone know the easiest 5 speed tyranny to put behind it ?
Old Mar 23, 2012 | 07:48 PM
PS- powerstroke. well we all have our opinions on engines, but you better lower your standards so you get disappointed
Old Mar 23, 2012 | 07:54 PM
97t444e's Avatar
PS= Powerstroke. and iv heard of people using the ZF5 or ZF6 but i think the most simple one to use is the NV4500.
IMO i would keep the 7.3 unless you are trying to get 800-900 HP then do the cummins but i dont see any need for that much HP unless you are into serious compition events
Old Mar 23, 2012 | 09:11 PM
ya but with the nv4500 dodge tranny i was wondering if i could use my t case? and will it line up with cross memeber mounts? or should i use dodge t case? just want the basics cleared up thanks
Old Mar 23, 2012 | 09:30 PM
it will not just drop in. i'd use NV4500 or the 5600. and dodge t case. so then you just need a custom drive line.
Old Mar 25, 2012 | 03:37 AM
fordcummins79's Avatar
the cummins swap is really easy to do go get the adaptor for the 5.9 to the ford zf 5-speed that will bolt to your tcase you need to make mounts or buy them all of that can be found at ford-cummins.com the adaptor is 600 and mounts are 279 use the ford 7.3 radiator and the dodge intercooler youll need to move the trans back 2 1/2 inches and everything else is cake i have done four of the same conversions myself including the two that that i own
Old Mar 26, 2012 | 06:48 PM
Ok what if I was to use the nv4500 to save money on adapter
i mean like if i found an nv4500 would it be just as easy? i found a zf5 for 500 bucks but it was from a 460 is that the same gear ratios and bolt pattern or is the diesel different
Last edited by codycatract; Mar 26, 2012 at 06:48 PM. Reason: Automerged Doublepost
