wheel dimensions???
Old Mar 21, 2012 | 11:12 PM
CumminsCrazed's Avatar
Default wheel dimensions???
ok guys, so im lookin at Fuel Boost wheels in a 17x9 size. What im wanting is the wheel/tire to stick OUT of my fender a bit (couple inches) for the off road/wide wheel/tire look. Theres 3 diff offsets and backspacing avail. for this wheel in the 17x9 size with the 8x6.5 bolt pattern. heres the sizing: MHT lists the Fuel wheels offset as "ET" in their tech specs - not sure what that means but id assume the offset is that number in mm?
Again im looking for the size that will push the wheel/tire outside of the fender some for that offroad/wide tire look.
Wheel size is 17x9
OS=Offset, BS=Backspace
OS....BS
20.....5.75"
1.......5"
-12....4.5"
Old Mar 22, 2012 | 09:34 PM
tiremann9669's Avatar
http://www.rsracing.com/tech-wheel.html
This should help.
Last edited by tiremann9669; Mar 22, 2012 at 09:35 PM. Reason: Automerged Doublepost
Old Mar 22, 2012 | 10:19 PM
ok i read all that, but it still didnt tell me what the best wheel option for BS and OS to get so the wheel/tires sits out away from the truck the most. thats offset chart gave me exact same dimensions that the wheel is.
Old Mar 23, 2012 | 12:37 AM
Measure yours, then figure out how much you want them to stick out, then using the link you should be able to figure out wich ones you want.
Old Apr 2, 2012 | 02:04 AM
Strapt In's Avatar
Rims are only part of the equation. You need to factor in tires as well.. I've get several second generation buddies running H2 wheels with Toyo 37"s and they stick out about an inch. Go with the 5" backspacing, the 4.5 will stick out to far. Unless you run a 6" lift.
Old Apr 23, 2012 | 04:46 PM
RAW's Avatar
RAW
Get these on yet? How about some pictures?
cutthroatxxx
Jun 22, 2015 10:16 PM
6.5dieselman
Feb 26, 2015 04:45 PM
FELTONMICHAEL
Dec 28, 2014 01:09 PM
NiNjAassasin545
Dec 2, 2014 11:40 PM
94ifs
For Sale
Oct 23, 2014 01:35 PM
