'01 F250 4x4 problems
Old Mar 20, 2012 | 03:47 PM
nickhuff's Avatar
Default '01 F250 4x4 problems
I recently purchased a 2001 F250 4x4 only to find out very recently that the 4wd isnt working. I test drove this truck before purchase and everything "appeared" to be ok. Trouble began this past weekend when we went to put the truck into 4wd and got no lights on the instrument panel. after doing some tracing i found that the electrical connector to the transfer case was not fully plugged in and as soon as i plugged it in and retried it i was able to get a fully functional instrument panel. The problem is that the truck is still not working in 4wd no matter whether i put it into 4 wheel high or 4 low (and yes i did change the hubs from auto to lock). I can see that front driveshaft turning but the front wheels will not turn. Found this one out the hard way by going down a sandy road and all but burying the truck. I hear the transfer case clicking in and watched the front driveshaft turning while i had someone else driving but just no pull outta the front wheels. Any ideas on what may be the cause of the problem?
Old Mar 20, 2012 | 04:02 PM
1999stroker's Avatar
Vacuum leak maybe causing the hubs to not fully lock, or could be bad hubs
Strokin' Away
Old Mar 20, 2012 | 04:39 PM
nickhuff's Avatar
Im new to the shift on the fly 4wd but isn't 4 high controlled by the vacuum and 4 low controlled by the hubs being locked? I just don't wanna throw parts at a problem but to me it sounds like hubs would bethe common element and more likely to be the problem????
Old Mar 20, 2012 | 04:55 PM
Its all controlled by vacuum.when you turn your air on does it only come out of the defrost vents? If so it's a vacuum leak somewhere in the system.
Strokin' Away
Old Mar 20, 2012 | 05:09 PM
nickhuff's Avatar
A/c works fine and switches between all vents properly
Old Mar 20, 2012 | 05:18 PM
Sounds like hubs then.but can't be 100% sure.pop your lug nut covers off and you'll see a snap ring pull those off and your hub pops right off, look for any broken gears or out of place pieces, then look at your hub and lock it in and out if you see no changing of gears moving then Id say hubs but you'll want to get a new rubber o ring and clip before you take them off. Riffraff or guzzles diesel o rings carries them.
Strokin' Away
Old Mar 27, 2012 | 03:11 PM
nickhuff's Avatar
well after tinkering around this weekend i found that when it is in 4wd the air does switch to blowing just out of the defrost vents. it looks like i am about to begin the hunt for a vacuum leak.
Old Mar 27, 2012 | 03:29 PM
Mdub707's Avatar
Vacuum leak aside, you can still manually turn the hubs and that should lock the hubs regardless. The hubs are dual purpose, either auto lock (vacuum) or manual lock (get your butt out and turn them by hand) so if you turn them by hand and still don't have 4x4, it's more than a vacuum leak bud...
manual or auto can be used for 4 high and 4 low. Not one for the other. Both work on both settings.
Old Oct 8, 2012 | 01:04 PM
nickhuff's Avatar
come to find out it was bad vacuum lines on back side of wheels. replaced and problem was solved. thanks for the help.
jimmer4dat
Sep 10, 2015 01:07 AM
Wyattbyrd
5.9L CR Performance
May 28, 2015 10:32 AM
tim12valve
May 3, 2015 11:02 PM
cummins1998.5
Jan 24, 2015 03:06 PM
Sculpturesylvan
Oct 18, 2014 10:19 PM
