1994 6.5l pouring oil!!!
Old Mar 19, 2012 | 11:28 AM
HCCREWCAB's Avatar
Default 1994 6.5l pouring oil!!!
i have a 1994 4x4 6.5l turbo diesel..right above the oil filter there are lines running into the block..one of them is pouring oil..i have a guess that it is the fitting where the quick disconnect oil line runs into...does anybody know the name of that fitting!!!! its a nut on one end that connects to the oil line and the other end is a threaded bolt that screws into the block im guessing.
thanks in advance
Old Mar 20, 2012 | 08:42 PM
gradyc's Avatar
I don't know what GM calls them but they are a quick disconnect and swivel for the oil cooler lines. they have a habit of wearing and leaking like that.The last one I worked on I had to get the fittings and hoses from Chevrolet.
Old Mar 21, 2012 | 08:53 PM
HCCREWCAB's Avatar
Yeah the part came in today and I believe I got her fixed...at idle is the oil psi supposed to be around 25-30???thanks
Daniel Finney
Oct 22, 2019 01:58 PM
Durtyd09
Nov 11, 2015 01:43 PM
soco
Jul 27, 2015 06:06 PM
sjslhill
Jul 22, 2015 01:02 PM
Glennvd44
Dec 20, 2014 04:02 PM
