99 f350 cummins build clutch cylinders
Old Mar 11, 2012 | 09:59 PM
deck60's Avatar
Default 99 f350 cummins build clutch cylinders
I am using a 98 12v nv4500 I have installed the ford master and dodge slave I have heard that the ford master wont work and I have heard that it will work so does any one know the answer
thanks all
Old Mar 12, 2012 | 08:00 AM
sb clutch's Avatar
FormerVendor
Yes give me a call and I will tell you what works.
Peter
800-988-4345
Old Mar 12, 2012 | 06:46 PM
deck60's Avatar
Peter
800-988-4345
thanks so much for the info Peter when I need a clutch I will be talking to you if all salesman were like you the world would be a better place
here is the link to my photobucket
http://s1125.photobucket.com/albums/l582/deck60/ford%20cummins/
Old Mar 13, 2012 | 07:57 AM
sb clutch's Avatar
FormerVendor
What a nice thing to say! It was a pleasure talking with you as well.
Peter
Old Mar 17, 2012 | 05:48 AM
timdale's Avatar
Deck 60, I'm using a ford master and dodge slave and works great. Mines a getrag but I can't imagine it's much diff than the nv
Old Mar 18, 2012 | 09:21 AM
deck60's Avatar
I talked to the guy at sb and he said that you need to match the bore and stroke to the ford and the one that comes the closest is a 95 jeep 4.0 I looked at one at advance it should work I have one coming what I like about this one is it has a bleeder the doege ones did not
Old Mar 20, 2012 | 10:28 PM
megancheung's Avatar
When I converted mine from auto to manual, I removed most of the trans harness. The only thing I saved was the reverse light wiring which I attached to the switch on the manual. Below the master cylinder is a couple of connectors that connect vehicle to trans harness. I connected the wiring at that point which bypassed the neutral safety switch. Let me know what engine trans combo you have and I can look up the diagram.
Old Apr 18, 2012 | 01:06 PM
12v99F350's Avatar
Are you talkin master or slave? What did you end up using? Peter at SB is out till Monday and my truck is down. I was using the Ford master and Dodge slave til this morning when the master broke loose from firewall. It had not been releasing entirely anyway. I have a slave/master complete unit, but no pushrod in the master.
Old Apr 18, 2012 | 02:02 PM
94cummins12v's Avatar
i tried the 94 ford master cylander and the nv4500 slave and it was a joke because of the clutch im running so i put in a set of valair hd nv5600 hydo kit and what a difference like haveing a stock clutch again
Old Apr 18, 2012 | 03:34 PM
12v99F350's Avatar
Ok, good. I'm too cheap for that so I got a used master/slave off a 00 Dodge, I have it all together but the original Ford master pushrod needs lengthened 3" and looks as though it will work in the Dodge master cylinder.
