clutch is getting heavy
Old Mar 4, 2012 | 01:00 PM
acblair801's Avatar
Default clutch is getting heavy
I have an 01 f250. Put a upgraded valair clutch in it almost a year ago. Stock clutch was already heavy and I don't recall this seeming any heavier after install but lately it feels to be getting heavier. Wife can barely push it in and it's wearing my knee out. My understanding is that the hydraulics either work or don't. Can they weaken causing a heavier pedal or does any know of an upgrade? Thank you for any insight.
If not I am going to attempt to make a longer pedal since it doesn't have to pressed to the floor like the stocker did.
Old Mar 4, 2012 | 01:42 PM
Sounds like you need to replace your stock hydraulics
Luke
Old Mar 4, 2012 | 01:57 PM
fordornothing's Avatar
i got my hydraulic kit from ford. it is a complete, pre bled kit an i paid about 240 i believe. if you go that route, where the line comes off the master to feed tha slave, there is a small roll pin that hold that line in place. superglue that pin or wrap some tape around it so that pin doesn't fall out. i say this because it happened to me.
Old Mar 4, 2012 | 02:49 PM
CMCA Swartzkrautheim's Avatar
Only thing u need it for is take offs anyway float the rest thas what'd id do but I'm broke that's probly y
Old Mar 4, 2012 | 03:06 PM
acblair801's Avatar
Thanks for info. Didn't want to replace hydraulics if it wasn't going to help but that appears to be what is necessary. I have been shifting without clutch but it gets tough when you're in town as i most often am.
Old Mar 4, 2012 | 03:18 PM
Valair1's Avatar
FormerVendor
I would look for binding problems, possibly a bent fork. loose master cykinder in the dash, broken firewall where the master cylinder fits.
Diaphram clutches are not usually very hard. I dont think its your hydro's.
Old Mar 4, 2012 | 06:25 PM
do you know if you have the updated clutch fork? the old style is known to bend and break.
Old Mar 4, 2012 | 06:31 PM
Clark Kent's Avatar
see post number 15:
https://www.dieselbombers.com/ford-p...tml#post818454
Old Mar 4, 2012 | 07:44 PM
acblair801's Avatar
i have the new style. No garage to work in so I may just wait till it warms up and drop tranny and clean and grease everything. I didnt get crazy with grease before because I was afraid it would get on the clutch disk. Put a new throw out bearing in but it is noisy. Possibly causing friction?
katman
5.9L CR Performance
Sep 10, 2015 03:34 AM
Turbo67
Jul 25, 2015 02:26 PM
lmshowalter
5.9L 24V Performance
Jul 16, 2015 06:39 PM
kryz9903
Jul 2, 2015 06:14 AM
Wyocumins
Oct 19, 2014 09:34 PM
