Studdering issue 99 7.3
Old Mar 4, 2012 | 10:47 AM
Farmer87's Avatar
Default Studdering issue 99 7.3
I have a 99 f250 that originally had the v10 in it but I have been rebuilding the truck and dropped a 99 7.3 in it. I got it to the starting point last week and it idles good but when you give it throttle it has a bad studder. I'm not sure if it's an injector or if it's bad injector o-rings. Or if it's another issue. If it is an injector how can I figure out which one it is to change it. Any help would be appreciated.
Old Mar 4, 2012 | 12:25 PM
CSIPSD's Avatar
I am assuming you have removed all traces of Gas from the fuel system, installed a Diesel fuel pump on the frame rails?
Old Mar 4, 2012 | 12:35 PM
Farmer87's Avatar
I have replaced everything from the fuel tank, lines, all electrical harness.
Old Mar 4, 2012 | 12:50 PM
CSIPSD's Avatar
How long have you had it running? It takes some time to get all the air out of the HPO system, just letting it idle will not pull the air out, which will cause some running issues.
Old Mar 4, 2012 | 01:58 PM
fordornothing's Avatar
i'd say you just have some air in the lines. take it out and run it.
Powerstroke36
Sep 29, 2015 07:16 PM
kevin krehel
18
May 14, 2015 05:07 PM
Rbear
May 3, 2015 07:47 PM
UniqueCopy
Dec 14, 2014 11:37 AM
7.3stroke
Oct 27, 2014 06:25 PM
