ford f250 diesel trans wont engage
Old Feb 28, 2012 | 03:30 PM
Kaleo Nakamura's Avatar
Default ford f250 diesel trans wont engage
i have a 83 f250 6.0 or 6.9 not to sure witch one and when i start it up it idles fine when i put into reverse it goes but once u get in to drive 2nd or 1st then it just dont do any thing its like its in neutral but once u get the truck on a hill of 15 deg or more then it will only go in drive but not reverse. please help
Old Mar 11, 2012 | 04:30 PM
4x4manonbroke's Avatar
check the filter, fluid level, and if that's ok then Ur pump or the converter are shot..... not cheep fixes either way unless u wanna learn about auto trans re-building.... i do some but not all......
Old Mar 12, 2012 | 02:32 AM
well we'v cleaned the filter and changed the fluid its getting a little better every time we change the fluid but its still not fixed. i hope its not the TC thou.
Old Mar 20, 2012 | 08:27 AM
well It sounds to me like your TC or the front pump are shot..... either way your gonna be pulling a trans out and doing some repairs........ there not really all that hard to do, you can get a book on how to rebuild your transmission.... you'll need to get a few specialty tools.... inner snap ring pliers, outer snap ring pliers, couple of small hooks, and a good clean place to re-build it all as close to dust free as possible....... not hard just time consuming...... if your willing to do the work its quite rewarding.... done a few my self...
Old Mar 20, 2012 | 04:25 PM
thank you for ur help and does any one have how any good info on how to take the transmission out and any thing that might might make doing the harder then it needs to be? and i got the exploded view of the trans so rebuilding should be ez.
Old Mar 21, 2012 | 11:18 AM
cowboyford16's Avatar
Taking it out is easy just clock the mlps on the side. And rebuilding it is easier said than done. Buy a shift kit they come with new and upgraded snap ring for the drums. Sandals make sure you spline the convertor twice if not you'll break the front pump
Old Mar 27, 2012 | 12:19 PM
Take the passenger side door off, pull the carpet off floor board( might need to remove the seat if its a bench seat) pull the dog house cover bolts out and put your engine hoist on the fathest reach, put in the passenger side dooe using a chain ( gonna be about 1000 pounds or so if 4x4) wrap one loop around the transfer case and one loop around the bell housing leaving plenty of room to drop trans and transfer case on ground through the dog house cover )in some cases at the highest point you will be close to the windshield so be careful) then un bolt the cross member and lower trans and transfercase down ( this helps to get to the bolts on the upper bell housing) then make sure your TC bols are un-bolted, and pull in away from the motor and lower the complete unit on ground......... you will need to jack up truck if its low, I lowered the entire unit on some cardboard and used a comealong to pull out from under the truck..... then you will need a clean area to pull the trans apart..... If I was you I would take the entire unit to the trans shop and have them test the transmission as they can determine weather or no its the TC or the front pump, or its just shot...... your choice... they might give you some insite.... rember when taking apart .... set everything in the order in wich it came apart.other wise you'll be guessing........
ish1521
Aug 26, 2015 08:42 PM
Dec 10, 2014 08:10 AM
