air in fuel
Old Feb 14, 2012 | 02:17 PM
muddyold7.3's Avatar
Default air in fuel
i got a problem my idi keeps gettin air in the fuel and i have no idea to pinpoint the source ill bleed the system at the valve on top of the fuel filter and as soon as i crank it up theres air in it again im thinkin it has to be form the filter back but i have no idea its really throwin me for a loop and its not reliabe i cant drive down the road without it dying on me and its my daily driver does anyone have any input im up to my *** in aligators tryin to fix this anything would be appriciated
Old Feb 15, 2012 | 02:18 PM
Oklahoma diesel's Avatar
First have you ever changed you overflow caps and orings on the injectors? Also check your selector, sometimes they get stuck and suck air. How much fuel is in your tanks?
Old Feb 16, 2012 | 05:26 PM
o rings and overflows are good i got prolly five gallons of fuel, what selector ?
Old Feb 16, 2012 | 09:36 PM
Your fuel selector valve, it's under your seat. What's the fuel gauge show on the dash. On my dads 92 at 1/4 tank it's empty.
Old Feb 16, 2012 | 09:53 PM
farmerdude's Avatar
sounds like you've got a pin hole in the supply line, in between the pick-up in the tank and the mech. fuel pump. If it was after the pump you would be able to see fuel squirting out. So i would start there. Also like OKdiesel said the tank switch valve is a possible. I had one that stuck in between tanks,and it would suck air.
Old Feb 17, 2012 | 04:10 PM
yea well my mechanic said its for some reason that my motors not burnin fuel right it has somethin to do with the glow plugs?
Old Feb 18, 2012 | 01:45 PM
I've never heard of that, if your glow plugs are bad it will be hard to start, after that it's self sustaining. Plus the glow plug and fuel are 2 different things.
Old Feb 19, 2012 | 01:15 PM
idk i fear its my injection pump $$$
Old Feb 19, 2012 | 02:12 PM
Only about 650
Old Feb 21, 2012 | 04:39 PM
yea thats alotta money and i hope it will fix my problems
also i got another question if i put a new injection pump on my truck ,i do have a turbo kit but my mechanic took it off to do a motor swap im going to put it back on thou can i get the turbo pump and run it naturally aspirated till i put my turbo back on
Last edited by muddyold7.3; Feb 21, 2012 at 04:39 PM. Reason: Automerged Doublepost
