94-98 7.3L Performance Discussion of 94-98 7.3 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
Rosewood Stage 2 and 2.5 Injectors
Old Feb 11, 2012 | 10:19 PM
97t444e's Avatar
Default Rosewood Stage 2 and 2.5 Injectors
Hey guys im new to this and im trying to decide which injectors to get. Im looking at rosewood satge 2 and 2.5. I have a 1997 f250 with exhaust, custom air and ts chip. I need to know if i could run these on a stock turbo and no IC? Im looking to eventuly get around 400 hp. Would i be able to run these sticks on what i have now if i keep the chip low and not running the truck hard? Finally which injector has more potential for power???
Thank you
Old Feb 11, 2012 | 10:43 PM
joebob3093's Avatar
Moderator
What's a stage 2.5? You can run either one on a stock Turbo with no IC but it will be hot and they should both make 400+
Old Feb 11, 2012 | 10:47 PM
97t444e's Avatar
A stage 2.5 is a 200/30 hybrid and how would they run if i just put the chip on stock setting?
Old Feb 11, 2012 | 11:31 PM
joebob3093's Avatar
Moderator
I would recommend an intercooler. They can be done pretty cheap and help alot even with the stock Turbo. They would run just fine. Why run it in a stock programing though?
Old Feb 11, 2012 | 11:40 PM
97t444e's Avatar
i am planning on adding a IC and How hot would it get if i ran it in like say the 50 hp setting? Also i plan on custom tunes.
Old Feb 11, 2012 | 11:44 PM
95powersmoker's Avatar
That stock turbo is not going to be happy for long. And an intercooler is going to be necessary otherwise it's going to get hot in a hurry...
Old Feb 11, 2012 | 11:47 PM
97t444e's Avatar
what are good options for intercoolers? i have heard guys running 6.0 ICs???
Old Feb 11, 2012 | 11:48 PM
Either a 7.3 or 6.0 intercooler... Need to get yourself an early 99 spyder and some pipes either custom made or work with some 7.3 pipes and customize those.
Old Feb 11, 2012 | 11:52 PM
97t444e's Avatar
ok were is the best place to find a 7.3 or 6.0 IC? and what is the difference between a e99 spyder and a late 99 spyder
Old Feb 11, 2012 | 11:54 PM
You can find intercoolers on craigslist, pullaparts, junk yards...
The e99 is smaller. it will mate to your turbo whereas the late 99 wont...
