replaced my vp44 and now it threw a p1688 code, Truck died on me!!!
Old Feb 10, 2012 | 09:57 PM
asabadin's Avatar
Default replaced my vp44 and now it threw a p1688 code, Truck died on me!!!
Ok I replaced my pump because I was having hard/ no start issue when it got warm. My truck has 237k on it and never replaced the pump. I replaced the vp44, lift pump, fuel filter, cam positioning sensor and crank positioning sensor while I had the truck down. Bled everything down properly from fuel filter, to pump to injector lines etc..Truck fired right up drove it around for a couple hours, then it just died and threw the p1688 code and will not start at all. I cracked an injector and supply line to injector pump, it's getting plenty of fuel and was spraying out. I am at a loss and ready to light my truck on fire!!!!!! specs of my truck are below
Old Feb 10, 2012 | 11:08 PM
mysterync's Avatar
Bad injection pump, doubt it would be the keyway with a 1688
Sent from my DROID BIONIC using Tapatalk
Old Feb 11, 2012 | 05:36 PM
asabadin's Avatar
damn really? It is brand new reman with warranty, not looking forward to yanking this thing off again it's a bitch
Old Feb 11, 2012 | 05:53 PM
mysterync's Avatar
It could be other things but a detailed diagnoses would lead you in the right direction. Just because a pump is new dosent mean it can't fail
In the same respect a code isn't a sure fire way to diagnoses the pump.
Old Feb 12, 2012 | 09:40 PM
cumminsman985's Avatar
Iv had a brand new reman vp44 fail within the first 100miles Boche says 1 out of every thousand or somethin close to that is defective.
