01 cummins shorted vp44 wires
Old Feb 10, 2012 | 07:36 PM
jcrad's Avatar
Default 01 cummins shorted vp44 wires
My truck was running fine till the two wires going into the vp44 shorted out due to a wire tap for an edge comp. Now the truck wont start. There is no power to the vp44 or the lift pump. I bumped the key 3 times to get codes but it reads NO BUS. I ran the VP44 stand alone bypassing all the computers and the truck STARTED. So now I'm thinking its the PCM. Anyone have any ideas? I gotta get this thing running ASAP. Is there any way to test the PCM?
Old Feb 13, 2012 | 05:49 PM
jcrad's Avatar
Default codes
I took the ecm off to get part numbers to see if I could locate a used one and then reconnected it and the truck started, but now its throwing codes. P 1693 and ECU 0237,0238,1475. Im thinking its a bad ground or bad connection somewhere. Where should I start?
JoeyMiR
9
Feb 3, 2018 10:05 PM
Shun70
Diesel Engine Conversions
Sep 21, 2015 01:39 AM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
