how much psi should my stock turbo running
Old Feb 7, 2012 | 03:36 PM
natureboy7's Avatar
Default how much psi should my stock turbo running
My 94 7.3 f350 turbo diesel runs at around 7psi I feel like that's a little low. how much should it be running at and what's the max my engine can handle?
Old Feb 7, 2012 | 04:55 PM
95powersmoker's Avatar
15-18psi stock at WOT...
Is your 94 a Powerstroke or an IDI with factory turbo?
Old Feb 8, 2012 | 08:49 AM
natureboy7's Avatar
Its a factory turbo but I don't know if its powerstroke or idI
Old Feb 8, 2012 | 08:57 AM
Where is your oil fill tube at? On the valve cover or in the front of the motor?
Old Feb 8, 2012 | 09:03 AM
natureboy7's Avatar
In front of the motor
You have an IDI... you're boost is probably right then..
Old Feb 8, 2012 | 09:05 AM
natureboy7's Avatar
How high can I make it before I start blowing things out
Old Feb 8, 2012 | 09:07 AM
I don't know much about IDI's, but i'm not sure there is a whole lot of performance upgrading to do to those trucks. They just run.
I don't think you need to worry about blowing anything up. Check out the IDI section below this section that your in and do some searching on things you can do.
Old Feb 8, 2012 | 09:10 AM
natureboy7's Avatar
Alright thank u
huntman7
Sep 17, 2015 10:03 AM
huntman7
8
Aug 28, 2015 05:42 PM
n2brk
Feb 21, 2015 09:05 AM
duramaxtuner
LB7 Performance
Dec 10, 2014 01:52 PM
GreenDieselF
Oct 20, 2014 02:05 PM
