baffle in air filter tube
Old Jan 29, 2012 | 07:59 PM
southernman1967's Avatar
Default baffle in air filter tube
just took this out along with silencer ring. now im hearing not too this. is this true need too hear from guys that have do this with mileage on there trucks.
Old Jan 29, 2012 | 11:09 PM
tower_ofpower's Avatar
Doesnt hurt anything, some people don't like the whistle of a turbo. So between the silencer ring blocking off the ports for the outer inducer fins and the baffle between the air filter box and turbo it all drastically cuts down on the whistle. Anything designed for "baffling" something can't be good for flow. Some things just work off of harmonic cancellations, gas engines do it alot. Different sized expansion chambers on the intake. All not necessary
Old Jan 30, 2012 | 10:49 AM
MillerBoyzDiesel's Avatar
Ive done it to a bunch of them, never seen any issue.
Old Jan 30, 2012 | 11:12 AM
steved's Avatar
Does 200k miles count??
Removed the baffles and the directional vanes at least 200k ago...made almost no noticeable difference, although I did find the directional vanes cocked slightly in the tube and partially blocking airflow.
Old Jan 31, 2012 | 01:26 AM
yes 200xxx does count thanks. but now im hearing taking all this out will burn your rings in the truck because the silica levels get too high especially if you run a aftermarket filter as i do. is this all crap or any truth too this?
Old Jan 31, 2012 | 05:10 AM
steved's Avatar
Cylinder scuffing is caused by poor air filtration...not removing the baffles (unless you caused an air leak from removing the baffles).
Old Jan 31, 2012 | 07:58 AM
TKC2000's Avatar
One of the first things I did was remove the silencer ring and baffling. I have 160k so far and no problems. I personally like to hear the turbo whistling.
Old Apr 21, 2013 | 09:50 PM
skoog_3451's Avatar
Im going to yank them in the morning!
and they are yanked. That was a pita!!
Last edited by skoog_3451; Apr 21, 2013 at 09:50 PM. Reason: Automerged Doublepost
Old Jun 26, 2013 | 06:11 AM
COMANCHE45's Avatar
Can someone post pics please? I'd like to do the same to mine!!
Old Jul 11, 2013 | 07:53 PM
5.9Cumminsturbodiesel's Avatar
i have done the same with my 03 no issues love the turbo whistle even more when i'm towing
jeffersonl
Nov 15, 2015 07:35 PM
Joebritt3210
Feb 11, 2015 01:44 PM
fire1296
Feb 4, 2015 06:15 PM
offroad00
Oct 27, 2014 06:50 AM
jeffersonl
Oct 25, 2014 06:46 AM
