238 cc hybrids
Old Jan 28, 2012 | 05:55 PM
twinboys's Avatar
Default 238 cc hybrids
What is magical about the number 238?
Old Jan 28, 2012 | 06:39 PM
joebob3093's Avatar
Moderator
they are easy to build
Old Jan 28, 2012 | 07:14 PM
twinboys's Avatar
...why? What makes them easy to build?
Let me try this: why not 235 cc or 240 cc?
Old Jan 28, 2012 | 08:30 PM
joebob3093's Avatar
Moderator
Don't quote me but its more or less taking the plunger and barrel out of a B code and putting them in an AB code core. Other sizes require machining parts.
Old Jan 28, 2012 | 09:27 PM
twinboys's Avatar
That's what I figured also, and will assume it is correct unless someone says otherwise.
The other thought I had, and maybe it's only a coincidence, is that a 238 hybrid is about the max for a stock 17* pump.
Next question: Why would someone want a stage 2.5 injector (around 200 cc)when it costs basically the same as a stage 3 (238 cc)? The only reason I can think of is to limit the power. Couldn't you accomplish the same thing through tuning and then be able to upgrade later with a much cheaper reburn? Is a 200 cc injector better than a 238 cc for some reason if both are tuned for the 200 cc capacity (assuming same nozzle)?
