Overdrive Light Flashing, Trans slamming into gear what to do???
Old Jan 27, 2012 | 10:39 AM
"SmokinIDI"'s Avatar
Default Overdrive Light Flashing, Trans slamming into gear what to do???
I have a 1994 ford f250 with a 7.3 idi turbo diesel and since i have owned it the overdrive light flashes and the transmission shifts really hard sometimes squeeling the tires! i was first told it was the throttle possision sensor but i have changed that. what else can it be?
Old Jan 27, 2012 | 01:11 PM
DieselConstruction's Avatar
could be transmission is shot worst case get it scanned the codes will tell you what is wrong
Old Jan 27, 2012 | 03:18 PM
i have scanned it many times and it is not reading any codes. the first time i scanned it, it was reading the throttle possition sensor and i replaced it along with some others on the rear end and on the transmission that were trashed due to mudding. but now it is doing the same thing but only with no codes.
Old Jan 27, 2012 | 04:15 PM
Red_Rattler's Avatar
High Tech Redneck
The od light flashing is the code.
Old Jan 27, 2012 | 04:27 PM
DieselCrawler's Avatar
ok, you replaced the TPS, did you set it correctly?
Old Jan 27, 2012 | 06:32 PM
ok thats what i was i was thinkin
Old Jan 27, 2012 | 06:43 PM
you need to scan for the actual transmission code for such as transmission slip code or torque converter
Old Jan 27, 2012 | 07:47 PM
could you maybe explain alittle furthur on that one im lost now
Old Jan 27, 2012 | 07:53 PM
ya man the overdrive blinking as you correctly said is a code to show without actually scanning with the obd2 or whatever the name of the actually scanner that the mechanic would actually use to see what the problem is and how to fix it that the computer would say was with the engine or transmission ya no what im saying or no?
nice 94 though man
Last edited by DieselConstruction; Jan 27, 2012 at 07:53 PM. Reason: Automerged Doublepost
Old Jan 27, 2012 | 08:36 PM
well i basically am the machanic and i have used the scanners quite a bit but are you saying that the blinking is the accual code, and that it would not come up on the scanner?
