Chevy Tahoe w/ turbo diesel...
Old Jan 20, 2012 | 01:46 PM
Hoffy85's Avatar
Default Chevy Tahoe w/ turbo diesel...
Does anyone on here have any info on the 2 door tahoes that gm/Chevy made stock with turbo diesels?
Old Jan 20, 2012 | 01:49 PM
03Powerstroke's Avatar
they were awsome
Old Jan 20, 2012 | 01:57 PM
Hoffy85's Avatar
I've got one that's a 95' and white 2 dr with a 6.5 turbo diesel. I've just been trying to find out info on them.
Old Jan 20, 2012 | 02:02 PM
your in the right section, what are you wantin to know?
Seydler3's Avatar
They're not power houses but they get pretty good fuel economy. The 94+ can be problematic with the PMD. The fix for that is a relocation kit. There are other problems as well but idk all of them since I own a mechanical one.
Sent from my Droid
Incredible 2 by HTC via Tapatalk.
Old Jan 20, 2012 | 02:08 PM
Hoffy85's Avatar
Just any info on them really. They're kind of strange since they're half tons but diesels. I've heard about relocating the ons but I haven't done it yet.
Old Jan 20, 2012 | 03:25 PM
Crazy's Avatar
Get PMD out from under the
if you have over 100,000 miles on the injectors it time replace them do the return lines and glow plugs at same time
if you running stock exhaust need to go with 3 inch down and at lease 3.5 inch cat back and get 97+ air filter set
keep oil change up
clean all grounds
You should be good to go for long time these are really good motors
Old Jan 20, 2012 | 04:44 PM
Hoffy85's Avatar
I haven't relocated the pmd yet or done the injectors. I've don't new high heat output bosch glow plugs. I've replaced the exhaust with 4" back from the turbo into a 6" tip (all straight piped, no cat or muffler). I've put on aftermarket Afe intake as well as a performance chip and guages. How would you even clean all the grounds? Seems like a pretty big chore.
Old Jan 20, 2012 | 05:31 PM
Crazy's Avatar
Ground not all the bad to clean
The computer grounds witch is 2 or 3 wires on right back of intake and right next to it on the firewall there 2 ground straps right under the AC Dryer one goes to head and other goes to the frame from the firewall. Then have the ground for PMD on top of the IP and one ground on right fender next to the battery check them make sure there clean and good ends on them and check straps really good make sure they don't ave no weak points
Old Jan 20, 2012 | 05:38 PM
Hoffy85's Avatar
What will cleaning and possibly repairing these grounds improve? Also does anyone know why they made these diesel tahoes or how many they made? Seems to be a rare truck.
