EBP valve / exhaust brake
Old Jan 17, 2012 | 05:47 PM
twinboys's Avatar
Default EBP valve / exhaust brake
I'm thinking about adding the switch to the Exhaust Back Pressure valve to make it into an exhaust brake. Another thread just mentioned a three position switch (on-off-stock). My idea is to make the "on" position have to also go through a relay controlled the IVS (idle validation switch). Anyone ever tried this or know of a reason not to?
Old Jan 17, 2012 | 06:02 PM
Haveastroke's Avatar
I too would be interested in this if it's possible
Old Jan 17, 2012 | 06:42 PM
fordornothing's Avatar
you can do it. i seen a thread on here some where. the only down side to this is, there is a 2- 3- 4 second lag from the time power is applied and when the valve actually closes. i wish it would close instantly.
Old Jan 17, 2012 | 08:28 PM
twinboys's Avatar
I think that lag is typical for even big trucks with factory brakes. I would be using it mostly when towing or hauling to save the service brakes in well anticipated brake action. I would still have full regular (service) brakes. I think I'll do it...just not sure when.
Old Jan 17, 2012 | 09:45 PM
OceanDiesel's Avatar
On a rig, the exhaust/jakes react the second your foot is off the throttle. If there is a delay, it is due to the driver still touching the pedal.
Old Jan 17, 2012 | 10:10 PM
twinboys's Avatar
Yeah, they probably do at least begin to react immediately. There is still at least a minor delay in actual full brake action. At least they seem to to me.
I think I may have over used "at least".
I guess my DIY kit will be worse and take some getting used to...but the price is right.
Momo12valve
13
Nov 9, 2015 09:54 AM
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Jake12valve
May 10, 2015 11:57 PM
russellflemister
Mar 18, 2015 09:08 PM
