Info on lifting my suburban
Old Jan 12, 2012 | 06:49 PM
urban-burban95's Avatar
Default Info on lifting my suburban
Hey guys
So Im thinking about lifting the burb 3'' suspension. To go this route will I need to alter brake lines/driveshaft ect or will the pinion angle of the shaft be ok after the lift? Anyone with a 3'' lift on their burban feel free to post pics on this thread please! Thanks in advance
Old Jan 12, 2012 | 09:02 PM
wpg6.5's Avatar
won't have to change a thing, just did one on my 1500. rough country 3 inch suspension. the torsions keys are a bitch and some grinding but if your good with your hands and can read instructions you will be fine
Old Jan 13, 2012 | 04:25 PM
We do all work in house, good to know nothing needs to be modified regarding the brake lines and driveshaft. thanks
I sent rough counrty an email, they only list a suspenion lift kit for 6 lug burbs.
Last edited by urban-burban95; Jan 13, 2012 at 04:25 PM. Reason: Automerged Doublepost
Old Jan 16, 2012 | 09:28 PM
wpg6.5's Avatar
gotta bend the brake like right by the brake out just a bit, but maybe not, thats like the only thing i had to do.
Old Jan 17, 2012 | 10:22 AM
So I can get 20" rims with 35 x 12.5 tires off a friend of mine. What lift would i need, 6"?
Old Jan 18, 2012 | 06:42 PM
wpg6.5's Avatar
ya forsure or cut the fenders and depending on back spacing may need spacers. the back probably would clear but front needs cutting for sure
Old Jan 19, 2012 | 04:57 PM
So my budget is tight, I'm leaning towards a 3" body lift. ive been researching a little and it seems like there are a bunch of modifications. Such as cutting the steering column and adding a 3" section, same with shift linkage. Also front and rear bumber brackets need modification. Fan shroud needs to be cut. Rad hoses and a/c lines need to be moved. all wires and metal lines need to be disconnected from frame. Ect Ect
what suspension kit would you guys recomend for a 3'' lift
Last edited by urban-burban95; Jan 19, 2012 at 04:57 PM. Reason: Automerged Doublepost
Old Jan 19, 2012 | 10:09 PM
wpg6.5's Avatar
rough country. i almost guarantee the 3 inch will fit 2500 or 1500. its super simple. not to expensive depends on the distributor. myn was just under 800 from a well priced place in winkler manitoba, that is canada. and thats with best shock you can get from them and add a leafs not blocks and a steering stabilizer. i fit 33 11.5's and i didn't even get my torsion keys in. on a 2500 I'm sure it would fit bigger.
ILLUSHA
Diesel Engine Conversions
10
Aug 21, 2015 05:48 AM
Stone007
Tech Article Submission
Jul 3, 2015 01:28 PM
tedbIII
Feb 1, 2015 11:09 PM
Dec 3, 2014 08:10 AM
760DAN
Oct 31, 2014 12:53 PM
