F350 Ford 2004 FICM readings...
Old Jan 1, 2012 | 11:16 AM
I'm fine F350 is not's Avatar
Default F350 Ford 2004 FICM readings...
Hello again - the 6.0 L is giving me trouble starting below -5 degrees celsius (140,000 km on truck)
Glow plugs were all replaced last week
Thought about getting the FICM replaced or repaired but first I have some readings here - any input would be appreciated
20 V - ignition on / engine off UNTIL GLOW PLUG LIGHT GOES OFF
when glow plug LIGHT GOES OFF - reading is then 48 V
48V - engine cranking
27V - engine running at 800 RPM
24V - engine running at 2000 RPM
Voltages increase slowly the longer the truck runs - both idle and 2000 RPM readings
As soon as the engine is turned off - key removed - voltages go back up to 48V and then slowly drop to zero V after a few minutes
Any suggestions would be appreciated - the first sign of this trouble was when the temp dropped to -5 degrees
Thanks
Old Jan 1, 2012 | 11:22 AM
03Powerstroke's Avatar
if it ever drops below 46-48v its bad.
mdub707(mike) fixes them.
DONT buy a new FICM, because it will be weak and eventually have the same issues.
Old Jan 1, 2012 | 12:04 PM
While reviewing other posts for 6.0 L starting problems - I wanted to mention that I have recently done an oil change 5,000km before temperature has dropped here in Canada and have used 5W40 synthetic oil - have I just created a problem or problems with this oil choice?
Old Jan 1, 2012 | 01:41 PM
hottip's Avatar
Your oil choice is not a problem. I agree , don't buy a new FICM because tou will need to get it reflashed at the Stealer, get it rebuilt.
Old Jan 1, 2012 | 07:15 PM
Thanks, It looks like I need a rebuilding of my ficm , I have read some units are bumped up to 56v output , Is this a good thing or am i looking for more problems if I use my f350 as a every day runner ( stock truck ) with minor towing .
Old Jan 1, 2012 | 07:23 PM
ive heard good things about a 58v FICM, i believe swamps does one...
Old Jan 1, 2012 | 07:33 PM
Thanks , Being an old school diesel teck this **** is new to me . Got this truck two years ago and has run great since this winter , never had a reason to go further then filter and fluid changes. being a newbie I am still finding my way around.How do I find swams or mike to ask more questions about the 56v system vs the 48v .And is any one running this voltage in there trucks
Old Jan 2, 2012 | 10:52 AM
Mdub707's Avatar
I sent you a PM buddy.
Old Jan 3, 2012 | 05:52 PM
Default waiting for ficm .
Getting a ficm done for me ( soon I hope ) But Just letting you all know my truck starts
if plugged in all day even though the ficm is only putting out 26 volts , not found on road dead yet .
I forgot to let you all now it is -15`c or about 0 `f .
Last edited by I'm fine F350 is not; Jan 3, 2012 at 05:52 PM. Reason: Automerged Doublepost
makuloco2000
Feb 15, 2015 02:31 PM
