fuel pressure
My 95 powerstroke hasn't started all week till today when we bled air out and pull started it. But when it sits for 12 hours doesn't want to start. Has no pressure at header. I put on code reader. No fault codes no check engine light but says I have 0 PS I at fuel rail. Please tell me my mechanical pump isn't bad
Fuel pressure is good. I noticed that the back of my valley had diesel in it. Could that pump be failing? I checked lines they are tight no cracks or leaks. Doesn't seem to be consistant. Took ten minutes for it to finally start
There is also a sensor that will back out of the threads or just go bad, on the right side of the fuel bowl. It's a cone shape. Just make sure that it's actually bad not just unscrewed before buying a new one because there 60 bucks!
cummins Pride
Oct 6, 2014 11:28 AM
