2004 6.5l duramax low oil pressure
Old Dec 15, 2011 | 08:11 PM
mvking1's Avatar
Default 2004 6.5l duramax low oil pressure
I am working on a 2000 chevy 3500 with a 6.5l duramax td. when idling and driving around the city and highway the oil pressure is fine. the only time it acts up and drops to zero for a split second is when exiting the freeway while slowing down. I can not recreate the issue at any other time. i have already replaced the ops checked the gage by grounding it out and it all seems to work. i havnt never seen this and i am looking for ideas.
Old Dec 16, 2011 | 04:49 PM
ebarresi5894's Avatar
didnt know they made a 6.5 duramax. could be a bad oil pump
Old Dec 16, 2011 | 05:09 PM
Crazy's Avatar
did you replace the OPS with ACdelco if not that maybe way when was the last time you change your oil and it could be bad filter i ran into that once it was bad filter
Old Dec 16, 2011 | 10:31 PM
MillerBoyzDiesel's Avatar
what year is the truck? i see 2004 then 2000
Old Dec 17, 2011 | 12:01 PM
mvking1's Avatar
it is a 2000 i dont know why i put 2004 the oil has a 1000 miles on it and it should have of been acdelco i got it from the dealership but didnt pay attention to the brand. I am going to check into the filter issue because that may have of been when it started.
Old Dec 17, 2011 | 09:55 PM
if you can get access to a scanner id go into the instrument cluster and watch displayed vs. monitored oil press. or hook up a temp. mech. oil gauge. the ecm monitors the oil press. and sends info. to the press. gauge. depending on how long the oil press. hits 0 you should be getting a dtc in comp. for something like oil press. sensor circuit low or something to that affect. replaced tons of instrument clusters on these trucks but never seen a prob with oil press. sensor or diff. filters.
robbyS
Apr 16, 2015 02:22 PM
jhprice
Mar 29, 2015 09:36 PM
Ruddedawg5.9
Mar 1, 2015 09:16 PM
powerstroke4178
Nov 27, 2014 02:35 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
