12 valve fuel pressure question
Old Dec 10, 2011 | 10:54 AM
cumminsf150's Avatar
Default 12 valve fuel pressure question
does any one have any specs on what the fuel pressure should be after the fuel filter, say at idle, wot, at wot i have 12 psi boost, which seems to be normal for this lagy mc lagerton exhaust housing i have, so say fuel pressure at idle, and wot with a max of 12 psi boost. i just had a filter clog up on me, and i replaced it which seems to have fixed the problem, but i want to install a gauge for future monitoring of the filter condition. 1991.5 12 valve ve pump, intercooled with a new lift pump, no intank pump.
Old Dec 12, 2011 | 09:19 AM
FASS Jeff's Avatar
You should be looking for 6-8 psi into the VE pump. I highly suggest getting yourself a fuel pressure gauge as well.
Old Dec 14, 2011 | 07:03 PM
thank you sir
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
cummins Pride
Oct 6, 2014 11:28 AM
