6.9L & 7.3L Performance Discussion of 83-94 6.9 and 7.3 Liter Ford Diesels Related to Performance and Longevity
digital odometer and sppedometer stopped working
Old Dec 4, 2011 | 03:57 PM
93 7.3L RIG WELDER's Avatar
Default digital odometer and sppedometer stopped working
Hey guys and girls i dont know a ton about this truck its a 1993 f 350 7.3 l turbo . I have a few problems i need help with, my digital odometer stopped working and my speedometer stopped working, also the cruise control stopped. i was thinking fuses i checked them all under the dash and on the fender wall. any other ideas??
Old Dec 4, 2011 | 04:55 PM
306_schmitt's Avatar
check underneath for broken wires or faulty speed sensor on the rear diff
the speed sensor will affect all those things
Last edited by 306_schmitt; Dec 4, 2011 at 04:55 PM. Reason: Automerged Doublepost
Old Dec 4, 2011 | 06:47 PM
The wires looked good will the speed sensor affect the speedometer and the digital odometer.
i replaced the speed sensor it did not work for the speedometer or the odometer , they said there was one on the transmission to so i guess i can do that one next.
Last edited by 93 7.3L RIG WELDER; Dec 4, 2011 at 06:47 PM. Reason: Automerged Doublepost
Old Dec 4, 2011 | 09:58 PM
rjjp's Avatar
Assuming you have an auto, don't drive it until it's fixed, the signal goes from the VSS to the PSOM (speedo) then to the computer, and the cruise. The PSOM could be fubar, got any salvage yards near you?
Old May 13, 2022 | 02:28 PM
BW42's Avatar
The speedo gets a signal from the vehicle speed sensor on the '93 -- this signal goes thru the RABS (anti-lock brake system), to the speedo, and then to the E4OD transmission controller. I fixed mine because someone on the weekly Diesel Bombers, speedo thread, mentioned that he had no dome light in the cab. Dome light is connected to the speedo circuit fuse -- fixed that with a fuse in the #8 fuse box position. This fuse also controls the speedo memory, and if it has no power, will immediately signal the tranny controller to go into limp mode. The tranny will revert to limp mode as long as there is no 12v on that line. With my truck being also a '93 IDI, electrical problems crop up for no reason except age. The forum guy who mentioned this said that his fuse showed good, but the connection inside the fuse separated, and the fuse tested out bad. Not sure what happened to mine, but it works now, and the fuse stays good, at least until the next time -- BW
