EGR delete without check engine light?
Old Dec 3, 2011 | 05:18 PM
bananawing's Avatar
Default EGR delete without check engine light?
Before all the advice to get a tuner and do all the deletes - DON'T BOTHER - it is not affordable right now.
I am tired of having my CE light constantly on (EGR unplugged). Maybe somebody can tell me if this combination might work and not cause a CE light or other problems.
1) Remove plunger from EGR motor
2) Remove white butterfly valve gear
3) Freeze plug to block EGR intake pipe
I tried just blocking the pipe, it ran like a gas engine with a stuck choke. In my mind (often wrong) when the computer thinks the truck should ingest black nasty air, it tells the butterfly to close, increasing the vacume on the EGR and the EGR to open up. Maybe the computer can be fooled with what I dreamed up.
Old Dec 3, 2011 | 06:57 PM
coors_man_2005's Avatar
there has to be a way to put resisters in like doing the dpf delete the cheap ez way just take some time figureing out what wires and what size
Higgy
Jun 5, 2015 09:16 AM
gauge1325
May 3, 2015 01:33 PM
dieseltuff
Ford Powerstroke 08-10 6.4L
Apr 27, 2015 07:18 AM
moneypitk5
Feb 12, 2015 11:01 AM
tbreddiesel
Thoroughbred Diesel
Jan 12, 2015 02:23 PM
