Block heater
Old Dec 3, 2011 | 10:21 AM
TOM81650's Avatar
Default Block heater
What the proper way to take the block heater out I need to replace it just having trouble getting it out or should I just install one on the heater hose?
Old Dec 3, 2011 | 05:18 PM
DieselCrawler's Avatar
on the heater there is a screw/bolt. loosen that while prying out on the block heater. once it is out, take some emery cloth and clean the area where the rubber oring sits. clean up the outside of the hole also. stick the new heater in dry and tighten the screw to the proper torque. overtorquing it will break the retaining clamp and it will fall out.
Old Dec 3, 2011 | 06:00 PM
TOM81650's Avatar
Ok i though so just couldn't tell if it was a screw or not thanks for the help
Old Dec 5, 2011 | 10:57 AM
Sandman8105's Avatar
I have been having to use mine more often lately. When I use it, she fires up immediately. If not, it takes some cranking. Just changed the controller and I know it is working. Changed the gp's about 1 year ago. Does it sound like I need to change them again to fix the problem?
Thanks,
Sandman
Old Dec 7, 2011 | 06:38 PM
Does ANYONE have an answer or insight on this?
Old Dec 7, 2011 | 06:47 PM
TOM81650's Avatar
ive never drove an idi that liked to start in the cold. everyone one of them just cranks and cranks and cranks before it fires with new or old glowplugs. just my experience
Old Dec 7, 2011 | 07:08 PM
Even when temps. are in the 60's, it does the same thing.
Old Dec 7, 2011 | 07:47 PM
why not test them and see if they are good.
Old Dec 9, 2011 | 06:32 PM
What is the best way with out specialty tools?
Old Dec 9, 2011 | 10:59 PM
test light. hook the aligator clip to POS battery terminal. unhook the wire to the glowplug and put the pointed side of test light to the glowplug top. if the light lights, the plug should be good.
ramrunner01
Feb 25, 2015 11:14 PM
94_12v
Jan 4, 2015 10:37 PM
bikernut
Audio Equipment/Electrical
Dec 18, 2014 03:30 AM
TheBeattie
Dec 4, 2014 07:53 AM
Low_Life_Style
16
Nov 29, 2014 06:28 PM
