94 6bt cummins swap into 86 chevy 2500
Old Nov 30, 2011 | 09:34 PM
dieselbuilder's Avatar
Default 94 6bt cummins swap into 86 chevy 2500
so i have an 86 chevy 2500 4x4 that i am planning on swapping a 94 6bt cummins into the vehicle. i have a few questions for u guru's out there, first is can i swap the engine into the truck and have enough clearance for oil pan, without having to install any lift? sounds like that is the only way to clear, and i dont want to do that. if i could clear by shortening the oil pan drop i would. any info or pics would be great. second question is are the internals to a dodge 241 t-case drivers side drop, the same/ or will they fit into a factory 208 chevy t-case pass. side drop? i have nv4500 im planning on installing, and would like to keep my original OEM chevy t-case. only reason i asked is because my spline counts that i need is different from what i have on my 208. any info on where to put holes in cab floor board would be great too. thanks for input and any pics would be greatly appreciated!!!
Old Dec 1, 2011 | 07:35 AM
andrewmp6's Avatar
The t case i have no clue on but for the motor mounts and engine crossmember look at Avalanche Engineering - (970)884-7716 - Extreme 4-wheeling parts and accessories to complete turn key vehicless or Page 11 or Mount & member package the first one takes a 4 inch lift the 2nd one no clue the last one is no lift at all.
Old Dec 21, 2011 | 11:00 AM
I found my mounts i neooeded, just looking for some feedback on the t- case
Old Dec 21, 2011 | 10:57 PM
andrewmp6's Avatar
What is the nv4500 from ?I think advance adapters might have a kit to use it.
Old Apr 11, 2012 | 11:26 AM
Does anyone have any pics of how they mounted theor hyd clutch master cylinder, just would likesome ideas other than what i ha e in mind
DieselDan370
Aug 23, 2016 02:24 PM
DirtyDiesel58
Jun 7, 2015 11:50 PM
ReckONE
Feb 25, 2015 09:41 AM
Dec 15, 2014 01:10 PM
dieseldude03
For Sale
Oct 2, 2014 07:53 AM
