seem to lack power on hills
Old Nov 25, 2011 | 11:57 PM
ddtyfz's Avatar
Default seem to lack power on hills
question? got a 92 f250 4x4 repowered with a 6.9 idi with a banks sidewinder running 10lbs of boost at the max 5lbs cruising it has the zf5 in it with 4:10 gears runs nice and smooth never had an issue as far as cold starts or anything i tried to turn the pump up one flat it didnt like that as far as egt goes so i put it back. but as soon as i come to a good size hill wich we have here in nwpa it struggles going up them in 4th gear empty almost to the point where i got to go into 3rd gear anybody have a solution? oh and it will want to reach the 900 range on the pyro and i guarentee the ip fuel screw wasnt in its stock pos. when i got the truck.
Old Nov 26, 2011 | 07:40 AM
DieselCrawler's Avatar
is this empty or with a trailer on it? mine pulls great over the hills here empty, loaded i might get down into 4th gear on the highway. sometimes even third.
Old Nov 26, 2011 | 01:13 PM
ddtyfz's Avatar
that is empty no trailer or anything
Old Nov 26, 2011 | 08:49 PM
how old is your pump and injectors? has it been properly timed at all?
Old Nov 27, 2011 | 06:43 AM
ddtyfz's Avatar
the pump i am not sure of the injectors where replaced last yr along with the return lines and o-rings. and as far as timing goes i have no clue it starts easy and runs smooth idles like a dream just seems to be losin it on the hills anymore
Old Nov 27, 2011 | 07:56 AM
how many miles on the truck? i got a feeling you pump is on its way out.
Old Nov 27, 2011 | 08:13 AM
ddtyfz's Avatar
the clock says 295000 but the guy i got the truck off of says it hasnt worked in a couple years so my guess is well over 300000 on it
Old Nov 27, 2011 | 04:36 PM
the pump and injectors have a standard life span of 100000-150000 miles. my guess is your pump is heading out.
Old Nov 28, 2011 | 11:39 PM
ALWAYSREADYROB's Avatar
Hey DC , I put a rebuilt I pump and I still got NO power at hills as well.....could it be I need new Injectors but wouldnt it smoke or run rough if that was the case ? what about bad GP s ? I havent checked them since I got the truck six months ago but again starts fine runs fkn great in flats but chokes on hills. Could it be the Turbo going out ?
Old Dec 24, 2011 | 11:32 PM
ddtyfz's Avatar
ok new pump had the garage install it starts up fine like always runs smooth still lacks on hills like it did before nothin different! except now my egt's climb so frikin quick. as soon as i hit a hill even a slight grade they go from 600 to 850 easy and i am empty a large hill i can hit 1000 in case u r wondering its got a banks waistgated sidewinder kit on it. i did adjust the fuel screw to get lower egt's but the power really lacks big time! i would say comp. or wore out motor but like i said it runs and starts fine even in cold weather it sat for 3weeks in cold weather 1 week being in the teens as soon as the wait to start light went out it fired after 3 rotations and purred not plugged in! could it be pump timing?
