wastegate adjustment
Old Nov 22, 2011 | 03:28 PM
87ford6.9's Avatar
Default wastegate adjustment
does anyone know which way i should adjust my wastegate to get it to spool up at lower rpm's?
Old Nov 23, 2011 | 05:18 AM
DieselCrawler's Avatar
that wont matter. can adjust it all you want it wont change low rpm boost.
Old Nov 23, 2011 | 11:03 AM
87ford6.9's Avatar
Ok...exactly what would the adjustment do?
Old Nov 24, 2011 | 11:15 AM
rjjp's Avatar
The wastegate is used to regulate max boost.
Old Nov 24, 2011 | 11:38 AM
87ford6.9's Avatar
Ok...so i would want to open it to increase boost i take it? I know i sound like a dumb a** but this is my first time messing with a turbo, so i appreciate the help!
Old Nov 24, 2011 | 06:08 PM
rjjp's Avatar
When closed it forces all the exhaust gasses to go through the turbine, and when it opens it allows some of the exhaust gasses to bypass the turbine, if you were to shorten the rod then it would take more boost to open the wastegate therefor increasing your max boost... Just don't give it too much with out head studs, don't want you to blow yer engine.
Old Nov 24, 2011 | 06:55 PM
87ford6.9's Avatar
ok...cool. thanks for your help!
Texasboy
5.9L Rotary Performance
Sep 19, 2016 12:06 PM
2gCummins
Jul 22, 2015 11:34 PM
wpg6.5
Feb 19, 2015 07:27 PM
marks86
Oct 23, 2014 03:25 PM
