93 6.5 swap into 84 gasser
Old Nov 20, 2011 | 06:06 PM
84RedTruck's Avatar
Default 93 6.5 swap into 84 gasser
I am planning on putting a 6.5 out of a '93 chevy 3500 into my '84 silverado that currently has a 350 gasser in it. Has anyone done this swap and do you have any tips before i get started?
Old Nov 29, 2011 | 09:52 AM
oldred's Avatar
Default 6.5 into gasser truck
easy cheesy. exhaust pipes will need a little work to fit up to the manifold, motor mounts should swap out, same bell housing. so, just need to figure out the coolant hoses, possibly a diesel radiator to deal with the newfound heat. and the fuel system, new lines, pump and or tank...i think it should be a bolt in swap type of deal with the right parts donor. & the electrical i'm not sure of..but it should pretty simple compared to the newer 6.5, as it should have a mechanical ip. and a throttle cable/possibly a pedal assy... i think it would be one of the easiest gas/diesel swaps out there.
Old Dec 1, 2011 | 07:30 AM
andrewmp6's Avatar
And a hydro booster too.
Old Dec 9, 2011 | 01:51 AM
peideyaya's Avatar
DirtyDiesel58
Jun 7, 2015 11:50 PM
penley`
Jun 7, 2015 04:38 PM
ReckONE
Feb 25, 2015 09:41 AM
twinboys
Ford Excursion 99-05 7.3L and 6.0L
Feb 8, 2015 11:41 AM
Mprudent
Nov 22, 2014 03:31 PM
