6.2 won't start
Old Nov 19, 2011 | 11:25 AM
jedibob's Avatar
Default 6.2 won't start
After repairing the injection pump cover (thanks for the help), I tried to start the engine today. I ran a fuel line with priming bulb from the lift pump to a container of fresh diesel. I bled the air out of the square filter in the firewall. I have one injector line disconnected, and only a drop or two of fuel has dripped out during about five minutes of cranking. Both batteries are new and charged, and I was using jumper cables to my car to keep the batteries charged. This truck has not run since before the motor was rebuilt about 5 years ago.
Any ideas?
Thanks, Robert
1984 GMC K20 4X4 6.2 diesel
Old Nov 19, 2011 | 04:30 PM
wildbill's Avatar
Re-tighten it, then try and start it again. IP won't build pressure with a line disconnected.
Old Nov 19, 2011 | 05:32 PM
jedibob's Avatar
followed directions. melted passenger side battery terminal
guess I should have waited more between attempts. going to parts store to find a more durable replacement.
Old Nov 19, 2011 | 05:43 PM
wildbill's Avatar
See if they got a gear reduction starter. They hold up to longer cranking times and draw WAY less amps.
Old Nov 19, 2011 | 07:20 PM
jedibob's Avatar
already have a gear reduction starter. the only unused parts on the engine are the lift pump and injector pump.
Old Nov 19, 2011 | 07:50 PM
wildbill's Avatar
Back together for another attempt?
Old Nov 20, 2011 | 10:06 AM
jedibob's Avatar
I bought a terminal but decided to leave it alone for the night. I'll start again in the morning when there is light outside.
Repaired terminal. tried starting again for over 5 minutes. No luck. checked that glow plugs were working. injector pump is getting power while starting. How can I tell if injector pump is bad?
Old Nov 20, 2011 | 11:24 AM
wildbill's Avatar
Check and make sure both solenoids "click" when you add/remove power. Also, make sure that you crack an injector line, then re-tighten it after 5 seconds of cranking. Alternate sides to. Takes a bit to purge the air out of the pump.
Old Nov 20, 2011 | 03:05 PM
jedibob's Avatar
working on it.
when I got this engine back from machine shop, it came with boxes of parts, some mine, some not, some missing. So this has been a big jigsaw puzzle for me (without having a picture to go by.)
I just realized that the injector return line is not installed. would that keep it from running?
Old Nov 20, 2011 | 04:56 PM
wildbill's Avatar
It won't. But what'll do, is make a mess without it. What's worse, there are hoses that come off of #1 and #2 injectors and tie into the line. If they're still there, your in luck and all you need is the steel line.
