Cold starting
Old Nov 17, 2011 | 02:09 PM
BigRigButters's Avatar
Default Cold starting
How cold does it have to be before it is required to plug in the block heater? It was 25 deg this morn truck would not start. I'm sure this thing should start up in temps lower than 25. I had a 240d benz that would not start if it was colder than 40, but it was on it's last leg. I've seen some 12v's start on WMO at 10 deg with only one battery. What is the coldest it can be and my IDI should still start?
Old Nov 17, 2011 | 06:04 PM
CARP's Avatar
I never plug mine in. Will start at any temperature. I suggest replacing the glow plugs and controller. I buy all my gp's and controllers from this site. www.AccurateDiesel.com - Accurate Technical Services, LLC
Old Nov 18, 2011 | 08:34 AM
And the controller? I'm sure it works fine. I'm tight on cash. I'm sure there is a testing procedure for the controller.
Old Nov 18, 2011 | 01:40 PM
CARP's Avatar
I'm not sure of a test procedure. But it sounds like the controller is faulty cause it doesn't keep the plugs lit long enough.
Old Nov 18, 2011 | 01:48 PM
I'll check my plugs. My controller is on a toggle. I know I have left it on before after a couple drives. I probably have a a plug or two out. I will keep the controller in mind.
Old Nov 18, 2011 | 04:04 PM
CARP's Avatar
Your plugs are manual? Then yeah. If you left the switch on for a drive those plugs will get eaten fast.....
Old Nov 18, 2011 | 11:22 PM
backwoodsracing's Avatar
use a push button instead it eliminates leaving them on
Old Nov 19, 2011 | 11:29 PM
DieselCrawler's Avatar
intall a push button or a momentary switch. also if they are on for longer than 10-15 seconds they will burn out. hopefully none of them swelled the tips or yo will in for some fun.
here, read up before attempting.
"Glow plug removal article"
Old Nov 22, 2011 | 10:29 AM
Brilliant idea on the switch! Thanks for the link on the glow plug removal. I will definatly follow that as close as i can. The glow plugs from these guys any good? -www.AccurateDiesel.com - Accurate Technical Services, LLC -
Or can I get a set from auto zone and expect similar reliability and performance?
Old Nov 23, 2011 | 08:04 PM
CARP's Avatar
I've had my gp's from accurate diesel in my motor for 40,000 miles. Starts at 0 degrees out every time.
