Help with 2000 hard to start
Old Nov 8, 2011 | 08:06 PM
nelson86m's Avatar
Default Help with 2000 hard to start
I have a 2000 7.3l, when its cold 50 deg. or less it cranks for a long time and when it does start it does a whomp whomp (for about 30 sec) like its missing bad then runs good. went to the ford dealer and they told me to replace the cam positioning sensor, replaced it nothing happend, and replace all of the glow plugs today and it still does it, any idea's what could be causing this? any help would be great, thanks
Old Nov 8, 2011 | 09:44 PM
CSIPSD's Avatar
Did you check to see if the glow plug relay is working?
Old Nov 8, 2011 | 11:31 PM
Clark Kent's Avatar
Is it just on cold starts or is it during hot starts as well?
Old Nov 9, 2011 | 12:45 PM
nelson86m's Avatar
Its just on cold starts, ill check the glow plug relay today and see if it is working. it has also done the rough idle as soon as u let of the throttle, but only a few times then it goes back to normal.
Old Nov 9, 2011 | 03:10 PM
nelson86m's Avatar
checked the glow plug relay, tested good. was wondering what the other relay is thats infront of the glow plug relay is for. circled it in red
Old Nov 9, 2011 | 05:05 PM
95powersmoker's Avatar
That would be the AIH relay...
Next time before you start it, check the level in the HPOP res. Should be within 1/2" of the top.
Old Nov 9, 2011 | 05:38 PM
DieselDanBoy's Avatar
how old's the fuel filter? and did this just appear all of a sudden or did it gradually get worse and worse over time?
Old Nov 9, 2011 | 06:47 PM
nelson86m's Avatar
the fuel filter was replace a couple months ago, haven't drove it much sense then. been doing it for a while, just getting worse the colder it gets out. bought it this spring. when warm it runs good, takes a little bit of cranking to get it to fire though, about 20 25 sec.
checked the level in the HPOP res. looked good 1/2" or less, but it was running today about 5 hours before i checked it.
Old Nov 10, 2011 | 04:17 AM
Clark Kent's Avatar
Ohm out the glowplugs for kicks too. Mine with 180k miles were 1.4 ohms each. The new Ford ones I installed where 1.1 ohms each.
Also, from what I read if your starter is weak, or batteries are weak, terminals dirty that the starter might not spin fast enough to kick the motor over. I would assume this would be worse if the motor is cold, but can't speak from experience.
A clogged fuel filter on mine was causing long cranking during cold and hot starts. And my filter clogged up in a couple of months of running diesel cleaner through every other tank on a truck that I allowed to sit for a year or two.
Old Nov 10, 2011 | 10:48 AM
nelson86m's Avatar
Cold start - YouTube
I took a video of it starting this morning while it was cold.
