om 617 oil leak at ip
Old Oct 29, 2011 | 11:31 AM
redneckvette's Avatar
Default om 617 oil leak at ip
the om 617 in my truck has leaked oil since I put it in, but it has always been a little here and there from the lower oil pan gasket but recently it started leaking quite a bit more. I got under it to investigate and it looks to have sprung a leak between the injection pump and the motor. i checked and all the ip mounting nuts are tight. is that an o ring or a gasket and does anyone know what all is involved in fixing it? any help would be appreciated. Redneckvette
Old Oct 30, 2011 | 12:47 PM
FTE's Avatar
FTE
It's a gasket and removal of the IP is required.
Old Nov 1, 2011 | 10:52 AM
i knew the ip had to come off but how involved is it to remove the ip. i have removed ip before on other diesels (6.2s 5.9s) but none that are ohc. if i remove the ip what is going to happen to the cam chain?
Old Nov 2, 2011 | 09:26 AM
FTE's Avatar
FTE
Nothing, just need to reset the timing when done.
Old Nov 12, 2011 | 06:42 PM
biffidum's Avatar
Have you ruled out the valve cover gasket as this is more common. If you do remove the IP I believe there is an MB tool for locking the pump. I wish I had more details, these are vauge recollections so google them up.
makuloco2000
Dec 20, 2015 11:19 PM
cummins Pride
Sep 28, 2015 12:11 PM
Gomerpile79
Apr 9, 2015 03:45 PM
pro graphic solutions
Feb 10, 2015 03:48 PM
ash23k
Dec 30, 2014 08:31 PM
